udf about mass diffusivity of multicomponent flow |
December 9, 2017, 19:38 |
zmliu
Rep Power: 16 |
the multicomponent flow includes four species. Mass diffusivity of the species is dependent of spatial coordinate. the udf as follows can be incorporated successfully. but a error "Divergence detected in AMG solver: species-0“ is displayed after I press "calculate" button. the udf is as follows.
#include "udf.h" DEFINE_DIFFUSIVITY(myudf,c,t,i) { real xc[ND_ND]; real diff; C_CENTROID(xc,c,t); if(i==0) { if(xc[0]>=-0.014&&xc[0]<=-0.006&&xc[1]>=-0.140&&xc[1]<=0.140&&xc[2]>=-0.140&&xc[2]<=0.140) diff=1.24e-11/80.34; else diff=5.88e-6 ; } else if(i==1) { if(xc[0]>=-0.014&&xc[0]<=-0.006&&xc[1]>=-0.140&&xc[1]<=0.140&&xc[2]>=-0.140&&xc[2]<=0.140) diff=1.85e-11/57.05; else diff=5.88e-6 ; } else if(i==2) { if(xc[0]>=-0.014&&xc[0]<=-0.006&&xc[1]>=-0.140&&xc[1]<=0.140&&xc[2]>=-0.140&&xc[2]<=0.140) diff=6.00e-11/28.68; else diff=5.88e-6 ; } return diff; } Can anybody help me on this please? regards |
December 12, 2017, 03:26 |
Refik
Rep Power: 12 |
At first glance, shouldn't there be a fourth elseif(i==3), since the mixture is composed of 4 species ? Also the error you get may not be related to your UDF, but to a large source/sink term for species. I found the link below regarding to the same error u get. Divergence Detected in AMG solver- Species 0 Regards. |
December 15, 2017, 03:30 |
zmliu
Rep Power: 16 |
Firstly thank you very much! secondly,The problem was solved,u r right that the error was not related to the udf.
thank u ver much! |
December 15, 2017, 06:11 |
Refik
Rep Power: 12 |
Hi, i am glad everything worked out well.
Can you please share how you solved the problem ? It can be of help / guidance to everybody out there as well. Regards. |
March 14, 2019, 12:51 |
AKHIL KUMAR
Rep Power: 7 |
could you please tell how you solved the problem
udf multicomponent |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 11:40 |
UDF for inlet mass flow rate | rahulsuresh89 | Fluent UDF and Scheme Programming | 1 | October 16, 2010 18:06 |
particle, parcel and mass flow rate balance | flybird | FLUENT | 0 | May 24, 2007 11:44 |
