[UDF compiling/debug]an integrated tool to edit/compile/debug UDF in Visual Studio |
November 10, 2017, 22:50 |
Rep Power: 17 |
Glad to announce the release of VcUdfStudio 1.0, which can edit, compile and debug FLUENT UDF in the Visual Studio IDE.
1.Easier to edit/compile UDF code (You can edit/compile/debug UDF in Visual Studio as soon as Visual Studio and this tool installed. No longer worry about how to config compiling environment.) 2.Enable debugging UDF code. (You can inspect variable values step by step in usual Visual Studio debugging way.) 3.Extended C++ function. (You can call Windows/VC++/MFC API in UDF code. DEFINE_EXECUTE_ON_UNLOADING UDF macro added to be execute when UDF library unloaded). Last edited by gearboy; November 16, 2017 at 20:22. |
November 12, 2017, 19:42 |
Alexander
Rep Power: 34 |
how to get it?
Best regards |
November 14, 2017, 21:41 |
Rep Power: 17 |
June 19, 2018, 02:58 |
Rep Power: 17 |
September 9, 2018, 22:20 |
Rep Power: 17 |
December 4, 2018, 06:54 |
Visual Studio 13 Ult Problem
Emerson
Rep Power: 8 |
I tried to install with my Ansys 16.0 and my VS 13 Ult. The Fluent toolbar worked but the VS didn't. I followed the tutorial and downloaded the extension Visual C++ MFC Multi-Byte-Character-Set Library. Do you know why the toolbar in my VS didn't show up? |
December 4, 2018, 20:02 |
#7 | |
Rep Power: 17 |
December 18, 2018, 10:48 |
Emerson
Rep Power: 8 |
December 19, 2018, 20:19 |
#9 | |
Rep Power: 17 |
We haven't got your email. Perhaps there is some blocks because this is a Chinese mailbox.
January 23, 2019, 00:59 |
#10 |
Rep Power: 17 |
July 3, 2019, 04:01 |
VC++ Udf Studio updated to 2019R2
#11 | |
Rep Power: 17 |
We have updated VC++ Udf Studio to support Fluent 2019R2.
Welcome to test and download from https://vcUdfStudio.bitbucket.io Quote:
UDF with fluent 6.3 and Visual S. 2008 | allen | Fluent UDF and Scheme Programming | 3 | October 23, 2012 04:53 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
UDF Error | Sid | FLUENT | 3 | July 2, 2007 10:34 |
error while compiling a udf | rahul | FLUENT | 10 | August 30, 2006 08:33 |
MS Visual Studio | ajay kumar | Main CFD Forum | 1 | February 20, 2006 21:28 |
