UDF to return assigned gauge pressure to a BC + mass flow rate
Like Tree1Likes
  • 1 Post By Tarantino
Old   September 25, 2017, 19:27
Question UDF to return assigned gauge pressure to a BC + mass flow rate
Tarantino
Tarantino is on a distinguished road
Hello!
I want to return an assigned pressure to a pressure outlet BC and do some math based on in a UDF. I want also to return mass flow rate.
Here is a part of udf that need to do so:
#include"udf.h"
real flow_tot, p;
DEFINE_ON_DEMAND(Pressure_flow)
Domain *d;
real flow;
cell_t c;
Thread *t;
face_t f;
d = Get_Domain(1);
t= Lookup_Thread(d, 29);
begin_f_loop(f,t)
flow+=F_FLUX(f,t);
end_f_loop(f,t)
p = C_P(c,t);
printf("gauge pressure = %g\n", p);
printf("Mass Flow Rate: %g\n",flow);
flow_tot =flow;
flow=0.;
However, when I compile and Execute-on-demand, then I got the following error:
Node 0: Process 13808: Received signal SIGSEGV.
Node 1: Process 17288: Received signal SIGSEGV.
Node 3: Process 17844: Received signal SIGSEGV.
Node 999999: Process 16332: Received signal SIGSEGV.
Node 5: Process 12176: Received signal SIGSEGV.
Node 6: Process 17444: Received signal SIGSEGV.
MPI Application rank 0 exited before MPI_Finalize() with status 2
 The fl process could not be started.
Anyone know the problem?
Thanks.
Svetlana likes this.
Tarantino is offline   Reply With Quote
Old   September 28, 2017, 20:06
Default eq?; use monitor
Svetlana Tkachenko
Svetlana is on a distinguished road
What pressure boundary condition do you want to set, if you write it in English and maths formulas?
For the mass flow rate you can add a monitor point, you do not have to add it to the UDF
Svetlana is offline   Reply With Quote
Exit Corrected Mass Flow Rate Mesh Sensitivity Study s__s__s CFX 4 July 20, 2016 12:46
UDF to access interior surface to calculate mass flow rate shahjehan Fluent UDF and Scheme Programming 0 August 11, 2015 15:44
DPM total mass flow rate yow FLUENT 0 July 17, 2015 13:01
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 14:14
Discrete Phase & Mass Flow Rate MagnusZeus FLUENT 0 December 2, 2011 18:57
