UDS problem
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   September 15, 2017, 00:48
Default UDS problem
Chi Zhang
C_Zhang is on a distinguished road
Hi everyone. I am writing a udf for three-phase-flow.After I hooked it to my model,it initialised well but can't calculate.Below are my udf.
#include"udf.h"
#include"unsteady.h"
DEFINE_ADJUST(store_gradient,d)
real unit_normal;
Thread *big_thread,*mixture_thread,*small_thread;
cell_t cell;
int current_iter,domainid,threadid1,threadid2;
current_iter=(nres==0)?(0)(int)count2[nres-1]);
domainid=8;
threadid1=1;
threadid2=2;
mixture_thread=Lookup_Thread(d,domainid);
big_thread=THREAD_SUB_THREAD(mixture_thread,thread id1);
small_thread=THREAD_SUB_THREAD(mixture_thread,thre adid2);
if((current_iter==0)&&(CURRENT_TIME==0))
begin_c_loop(cell,big_thread)
C_UDMI(cell,big_thread,0)=0;
C_UDMI(cell,big_thread,1)=0;
C_UDMI(cell,big_thread,2)=0;
C_UDMI(cell,big_thread,3)=0;
C_UDMI(cell,big_thread,4)=0;
end_c_loop(cell,big_thread)
begin_c_loop(cell,small_thread)
C_UDMI(cell,small_thread,5)=0;
C_UDMI(cell,small_thread,6)=0;
C_UDMI(cell,small_thread,7)=0;
C_UDMI(cell,small_thread,8)=0;
C_UDMI(cell,small_thread,9)=0;
end_c_loop(cell,small_thread)
if (!Data_Valid_P())
return;
C_UDSI(cell,big_thread,0)=0;
C_UDSI(cell,big_thread,1)=0;
C_UDSI(cell,big_thread,2)=0;
Message("helloworld");
return;
real integrand(real scale,real density,real diameter,real tension,real dissipation)
real answer;
answer=exp(-12*diameter*diameter*tension/(density*2.047*pow(scale,11.0/3.0)*pow(dissipation,2.0/3.0)))/pow(scale,4.0);
return answer;
real integrand1(real scale,real density,real diameter,real tension,real dissipation)
real answer;
answer=exp(-12*diameter*diameter*tension/(density*2.047*pow(scale,11.0/3.0)*pow(dissipation,2.0/3.0)))/pow(scale,11.0/3.0);
return answer;
DEFINE_PROPERTY(diameter,c,t)
real diameter1,surface_tension,density_of_continuous,vi scosity,voidreturn;
Thread *mixture_thread,*big_thread;
int threadid;
threadid=1;
density_of_continuous=998.2;
surface_tension=0.0719404;
viscosity=0.001003;
mixture_thread=THREAD_SUPER_THREAD(t);
big_thread=THREAD_SUB_THREAD(mixture_thread,thread id);
voidreturn=1;
if(C_VOF(c,t)==0)
diameter1=0.0008;
else
diameter1=1.78*pow(sqrt(surface_tension/((density_of_continuous-(C_R(c,big_thread)*C_VOF(c,big_thread)+C_R(c,t)*C_ VOF(c,t))/(C_VOF(c,big_thread)+C_VOF(c,t)))*9.81)),0.889)*po w(viscosity/density_of_continuous,0.0836)/pow(C_D(c,mixture_thread)*C_VOF(c,t)/(C_VOF(c,big_thread)+C_VOF(c,t)),0.0279);
return (diameter1);
Attachment is what I did in user defined scalar dialog box. All my three scalars have the same setting.
C_Zhang is offline   Reply With Quote
Old   September 15, 2017, 00:50
Chi Zhang
My udf seems strange because it's too long and all parts excluded in this webpage have been set between /* and */ so they won't execute.
Old   September 15, 2017, 00:54
Chi Zhang
I am sure the problem is on UDS because when I set 42nd,43rd and 44th line between /* and */, it works well.
Those lines are
Old   September 15, 2017, 01:00
Chi Zhang
I will appreciate any of your help
Old   September 15, 2017, 03:07
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you are using multi-phase flow, do I not know how to start such cases properly.
However, you are using begin_c_loop(cell,big_thread) and begin_c_loop(cell,small_thread) to set/calculate variables for specific regions.
But what values do these variable have at other regions?
I did not test it, but what if UDS values should be defined everywhere?
In that case you need loop over all threads to initialize UDS values, but then you may modify values of UDS variables in specified regions.
I hope my idea is clear.
Best regards,
Zorin Alexander
AlexanderZ is offline   Reply With Quote
Old   September 15, 2017, 03:12
Chi Zhang
Dear Zorin
Thank you for your help first.
UDS is only used to calculate the second order gradient of void fraction of each secondary phase in my UDF. Do you have any suggestions?
Old   September 15, 2017, 03:22
Alexander
Try to use loop over all threads for UDS for initialization
cell_t cell;
Thread *thread;
thread_loop_c (thread,domain)
		begin_c_loop (cell,thread)
                   C_UDSI(cell,thread,0)=0.0;
		end_c_loop (cell,thread)
C_Zhang likes this.
Old   September 15, 2017, 03:25
Alexander
or you may try to use big_thread directly, however, I have never tried it before:
thread_loop_c (big_thread,domain)
		begin_c_loop (cell,big_thread)
                   C_UDSI(cell,big_thread,0)=0.0;
		end_c_loop (cell,big_thread)
Old   September 15, 2017, 03:32
Chi Zhang
I'm sorry maybe I gave you too little information.
Actually, I want to get the second order gradient of void fraction for each secondary phase, but I don't know how to do. This way is found from some predecessors' threads here in this forum. Since I don't know its detail, I may have made some mistakes on using UDS as well as on setting something in GUI. Do you know some effective ways to get second order gradient?
Thank you very much
Old   September 15, 2017, 03:33
Chi Zhang
Oh! your reply is so quick, I should read it first
Old   September 15, 2017, 03:52
Chi Zhang
looping over all threads in subdomain works! But I am still confused. Why do I have to loop over all threads in subdomain?
Old   September 15, 2017, 04:30
Alexander
Frankly speaking, I do not know,
may be the reason is that fluent tries to calculate scalar everywhere, so without initialization it gives error
Best regards
Old   September 15, 2017, 04:36
Chi Zhang
Thank you.Fluent is a mysterious software
UDS problem with wall boundary condition Alex F. FLUENT 15 September 21, 2015 10:28
a stupid UDS problem bgu Fluent UDF and Scheme Programming 0 August 18, 2013 07:52
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 05:26
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
