August 24, 2017, 01:41 |
fluent udf thermal conductivity
bob lu
Rep Power: 9 |
Hi everyone,
I'm modeling the process of selective laser melting using FLUENT.And, there are two sets of data of thermal conductivity . in the begining, the thermal conductivity of powder system equals to powder when the working temperature is below the melting temperature and when the temperature exceeds melting temperature the thermal conductivity of powder change to bulk . I want to know which code could help me implement the function. thank you |
August 24, 2017, 02:28 |
Kirill Borodin
Rep Power: 10 |
Hello! Does thermal conductivity depend on temperature only?
Sent from my Redmi Note 3 using CFD Online Forum mobile app |
August 24, 2017, 02:43 |
#3 | |
bob lu
Rep Power: 9 |
the effect that i want to achieve is like if(the temperature of this cell never exceeded melting temperature ) thermal conductivity=powder; else thermal conductivity=bulk; thank you for your reply |
August 24, 2017, 02:53 |
Kirill Borodin
Rep Power: 10 |
Check the udf manual, there is an if/else condition in 2.3.18 for DEFINE_PROPERTY macro in Example 1. It's used for viscosity definition there, but one can use this macro for any physical value
August 24, 2017, 03:12 |
#5 | |
bob lu
Rep Power: 9 |
August 24, 2017, 05:22 |
Kirill Borodin
Rep Power: 10 |
The first thing that comes to mind is making a list of cells, and if the temperature in a cell reaches the border, one puts a boolean value in the list, and for each iteration we make such procedure
August 24, 2017, 05:29 |
#7 | |
bob lu
Rep Power: 9 |
it is what i mean, so do you know which udf code can help me achieve it, like MPCHG in ansys APDL |
August 24, 2017, 06:28 |
KirMaks
Rep Power: 10 |
Hallo, you may use UDM for this, take a look on DEFINE_EXECUTE_AT_END and put some logic there: loop through Your cells in the required region and put "0" or "1" into the UDM.
August 24, 2017, 08:52 |
#9 |
Kirill Borodin
Rep Power: 10 |
Check the example in 3.2.6.3 in udf guide and modify it. You may print cell centroids and a boolean (maybe with temperature) in a single macro
August 25, 2017, 04:28 |
#10 |
bob lu
Rep Power: 9 |
August 25, 2017, 04:33 |
#11 | |
bob lu
Rep Power: 9 |
THANKS, ANYWAY. |
August 25, 2017, 16:06 |
#12 |
Kirill Borodin
Rep Power: 10 |
Congratulations! Can I see the code please?
August 26, 2017, 22:35 |
#13 | |
bob lu
Rep Power: 9 |
{ real tc,T; T=C_T(cell,thread); if(T>=873) C_UDMI(cell,thread,0)=1; else; if(C_UDMI(cell,thread,0)==1){ if(T<=300) {tc1=237;} else {tc1=0.041*T+224.7;} } else { if(T<=673) {tc1=5;} else {tc1=-284.39+0.43*T;} } |
August 27, 2017, 16:38 |
#14 |
Kirill Borodin
Rep Power: 10 |
A Problem of Fluent Interpreted UDF: parse error | knight | Fluent UDF and Scheme Programming | 25 | August 16, 2018 11:26 |
UDF for thermal conductivity relation of nano fluid | ngonbadipoor@yahoo.com | Fluent UDF and Scheme Programming | 29 | April 1, 2017 04:02 |
UDF for thermal conductivity | ayoub1989 | Fluent UDF and Scheme Programming | 5 | August 18, 2014 06:15 |
UDF for effective thermal conductivity in porous media | dotapro | Fluent UDF and Scheme Programming | 17 | February 24, 2014 11:56 |
Porous Media Effective Thermal Conductivity | Greg Perkins | FLUENT | 3 | August 5, 2001 22:53 |
