UDF of temperature at wall (fluent B.C)
Like Tree2Likes
  • 1 Post By Jerol
  • 1 Post By MayTheFlowBeWithYou
Old   August 9, 2017, 18:51
Smile UDF of temperature at wall (fluent B.C)
Jerol Soibam
Jerol is on a distinguished road
Hello Everyone,
I am relatively new with UDF concept in fluent. So, kindly help me.
I want to impose a variable temperature along the wall (x-axis) which varies linearly (493 K to 473 K) and I want the temperature to reduce to 298 k after an hour. So, I went and wrote this code, but I am not sure if this is the correct way. Kindly, correct me if this is wrong.
Thank you \
#include "udf.h"
DEFINE_PROFILE(temp, thread, position)
face_t f;
real x;
real t = CURRENT_TIME;
begin_f_loop(f, thread)
x = F_T(f,thread);
if (t<3600)
F_PROFILE(f, thread, position) = 493 - 66.667 * x;
else
F_PROFILE(f, thread, position) = 298;
end_f_loop(f, thread)
Oula likes this.
Jerol is offline   Reply With Quote
Old   August 14, 2017, 06:59
MayTheFlowBeWithYou's Avatar
I have to remain anonymous, I'm sorry.
Location: The Netherlands, Delft University of Technology
MayTheFlowBeWithYou is on a distinguished road
It's almost correct:
#include "udf.h"
face_t f;
real x;
x = F_T(f,thread);
if (t<3600){
else
Oula likes this.
MayTheFlowBeWithYou is offline   Reply With Quote
Old   October 3, 2018, 14:57
Oula
Oula is on a distinguished road
Dear Jerol and MayTheFlowBeWithYou
Thank you for sharing these codes, in my case I need to inject a certain amount of gas flow rate through an inlet pipe, the injection of the gas is periodic during the simulation i.e. same amount of gas flow rate to be injected every one hour of the physical flow time. Do you know how can I code a UDF for this case
Any help is appreciated.
Oula is offline   Reply With Quote
Old   March 15, 2019, 09:55
Default coupling temperature variation with fluid flow
gouravjee is on a distinguished road
#include "udf.h"
face_t f;
real x;
x = F_T(f,thread);
if (t<3600){
else
Hii All,
I have been working on a heat exchanger problem in which the molten metal kept stationary in outer shell of a concentric tube and a fluid is flowing in the inner tube.
I am using UDS scalars to define temperature and velocity but results do not show any variation in temperature profile of fluid part(even if flow is there) and remains same as the stationary fluid
kindly provide me some hint regarding this problem
Thanks in Advance
gouravjee is offline   Reply With Quote
define wall functions (UDF) in Fluent 6.3 Alex FLUENT 6 August 3, 2017 08:45
Is wall ajacent temperature equal to conservative temperature of the wall? shenying0710 CFX 8 January 4, 2013 05:03
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 07:08
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
