Write uds to results
Like Tree1Likes
  • 1 Post By MayTheFlowBeWithYou
Old   July 4, 2017, 06:15
Question Write uds to results
MayTheFlowBeWithYou's Avatar
I have to remain anonymous, I'm sorry.
Location: The Netherlands, Delft University of Technology
MayTheFlowBeWithYou is on a distinguished road
Dear cfd-online community,
For a simulation I'm trying to do, I made a UDF that utilizes two UDS's. The code runs perfectly fine, but the problem is that fluent only writes the solution of one of the UDS's (I can't see uds-1 in CFD-post). I am 100% sure that I allocated space for two UDS's (uds-0 and uds-1) and that both of them are present since they have an inlet (in fact, they both have the same inlet and are introduced to the system in an equal amount). I am also 100% sure that uds-1 is actually present during simulation, since I can make my UDF printf the values during the iterations.
Does anyone know why uds-1 doesn't get written to the results?
MayTheFlowBeWithYou is offline   Reply With Quote
Old   July 11, 2017, 10:27
Just as an update to whomever finds this thread for the same issue. I didn't find the answer yet, but I have a work-around. In Fluent 18.1 if you go to File -> Export -> Solution Data..., you can write a "custom" solution file where you can choose which variables you want to write. I just choose CFD post compatible, write the file and then open a separate CFD-post where I load this file.
It's less convenient than the automatic functionality from fluent (which I still believe should also be able to do this, I just don't know how), but it works. Additionally you can also write other formats like ASCII or tecplot.
bestucan likes this.
aaaaaaaaawwqqqqqqqqqqq
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 12:33
how to build a txt file and write the results in? roy FLUENT 0 August 22, 2005 22:36
A good question about UDS Z FLUENT 1 March 31, 2005 16:14
UDS transport: strange results Ale FLUENT 1 November 6, 2003 07:28
