face loop on looked up thread within DEFINE_PROFILE causing error
Like Tree10Likes
  • 2 Post By PanPeter
  • 1 Post By KaLium
  • 1 Post By PanPeter
  • 1 Post By KaLium
  • 3 Post By PanPeter
Old   June 13, 2017, 11:05
Default face loop on looked up thread within DEFINE_PROFILE causing error
Fynn
PanPeter is on a distinguished road
Hi together,
I encountered a weird problem and hope somebody can give me someone hints as to how to solve this:
I want to define an inlet velocity profile which is related to the outlet velocity profile. My approach is to write an udf for the inlet:
The DEFINE_PROFILE loops over all faces of my inlet surface and assigns velocity values of my outlet surface to it. For that I have to create a loop over the outlet faces and that's where my problem arises. The values in my loop over the outlet values could not be read.
I reduced my problem to the following udf, in which I only count and print in my outlet loop. That triggers the "received a fatal signal (Segmentation fault)" error when the compiled library is loaded.
Interestingly, if the Message() command is left out, everything runs smoothly. How can the Message() command have such an effect?
DEFINE_PROFILE(x_velocity_inlet, thread, i)
	face_t f;
	Domain *domain;
	Thread *t_out;
	int Zone_ID=3;
	domain=Get_Domain(1);
	t_out = Lookup_Thread(domain, Zone_ID);
	int counter = 0;
	begin_f_loop(f, t_out)
		counter = counter + 1;
		Message("hello %d\n", counter);
	end_f_loop(f, t_out)
	begin_f_loop(f, thread)
		F_PROFILE(f, thread, i)
			= 2.0;
	end_f_loop(f, thread)
Svetlana and unicrey like this.
PanPeter is offline   Reply With Quote
Old   June 14, 2017, 08:09
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
 F_PROFILE(f, thread, i)  = 2.0;
Why you are using thread here and not the t_out
Svetlana likes this.
KaLium is offline   Reply With Quote
Old   June 14, 2017, 08:29
Fynn
Hi Kal-el,
In the second loop I define the velocity profile to the surface that the macro is called on. It is called thread here, in my simulation, it is the inlet boundary.
But the crucial part is the first face loop on the thread t_out:
The error is thrown when the Message() is defined. If the Message() function is not defined the counter is still not updated in the loop. Something is odd when looping over faces of an looked-up thread but I can't see why this shouldn't work.
cheers,
Fynn
Old   June 14, 2017, 08:31
KaLium's Avatar
Kal-El
Have you tried Message0() ?
Are you sure that this loop does anything:
int counter = 0;
https://www.sharcnet.ca/Software/Ans...e_profile.html
The solver passes only the pointer to the thread associated with the boundary zone to the DEFINE_PROFILE macro.
note also:
Note that unlike source term and property UDFs, profile UDFs (defined using DEFINE_PROFILE) are not called by ANSYS Fluent from within a loop on threads in the boundary zone.
Old   June 14, 2017, 09:39
Fynn
Hi, I figured it out:
The problem was that I used a wrong zone id for my outlet thread.
But I still encounter problems looping through face elements:
DEFINE_EXECUTE_AT_END(meanVelOnSurface_atEnd)
	face_t f;
	Thread *thread;
	Domain *domain;
	domain = Get_Domain(1);
	int Zone_ID = 1;
	thread = Lookup_Thread(domain, Zone_ID);
	real vel = 0.0;
	begin_f_loop(f, thread){
		vel += F_U(f, thread);
 	}end_f_loop(f, thread)
	Message("sum velocity = %g\n", vel );
This compiles and loads well but when it is executed, it throws a Segmentation fault error. Any idea what's odd about this?
cheers,
Fynn
Old   June 14, 2017, 09:54
Fynn
Also, when F_U() is not defined and I simply have a counter in the loop,
it seems to count through a different surface:
	face_t f;
	Thread *thread;
	Domain *domain;
	int Zone_ID = 1;
	real vel = 0.0;
		vel += 1.0;
My surface list output is:
surface group name          id    points  0D facets   1D facets   2D facets
inlet                        2        19          0          18           0
interior-channel             3      2268          0        4147           0
line                         4        19          0          18           0
outlet                       1        19          0          18           0
walls                        0       234          0         232           0
and my program produces as output, "sum velocity = 4147". But that's not the face number related to the surface with id = 1 (outlet).
Old   June 14, 2017, 10:11
Fynn
Ok, now I got it figured out:
It was again a wrong zone ID:
It was wrong to use surface IDs from surface list. They are different from the IDs that are stated in the boundary dialog box (as suggested in the documentation).
With the ID from the dialog box, which is for some reason 6, the program works fine.
Thanks for the help.
Fynn
Svetlana, unicrey and jakub_ like this.
Old   June 22, 2017, 11:51
Vedamt Chittlangia
vcvedant is an unknown quantity at this point
Hi PanPeter,
I am working on a turbulent flow problem to access TKE at the symmetry boundary condition and am using the face loop as you are using.
The problem is that I get segmentation fault when I try to access F_K(f,t). Though F_CENTROID(x,f,t) works fine. I think this is due to TKE not present at that boundary.
Any ideas to work it through?
vcvedant is offline   Reply With Quote
begin_f_loop, define_profile, lookup_thread, message passing
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
