Automatically raise certain under-relaxation factors every n iterations
Like Tree2Likes
  • 1 Post By KaLium
  • 1 Post By voa_cfd
Old   June 7, 2017, 10:18
Question Automatically raise certain under-relaxation factors every n iterations
voa_cfd's Avatar
voa_cfd is on a distinguished road
Hello CFD-user,
for my stationary simulation i want to raise the under-ralaxation factors in the solution controls menu every 300 iterations by 0.2. Is there a way to handle this using for example an udf?
Changing the values manually every time is very annoying, cause there are about 5000 Iterations to calculate.
In the ANSYS Manuals i couldn't find something about it.
Thanks for your answer.
voa_cfd is offline   Reply With Quote
Old   June 8, 2017, 07:44
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
You can control them with console commands -> You can make a journal
voa_cfd likes this.
KaLium is offline   Reply With Quote
Old   June 8, 2017, 17:12
Smile
voa_cfd's Avatar
Thank you KaLium, now it works great with the following journal file:
solve/set/under-relaxation/pressure 0.1
solve/set/under-relaxation/mom 0.5
solve/set/under-relaxation/k 0.5
solve/set/under-relaxation/e 0.5
solve/iterate 300
solve/set/under-relaxation/pressure 0.12
solve/set/under-relaxation/mom 0.52
solve/set/under-relaxation/k 0.52
solve/set/under-relaxation/e 0.52
solve/iterate 300
or shorter:
so set ur pres 0.1 mom 0.5 k 0.5 e 0.5
solve/iterate 300
so set ur pres 0.12 mom 0.52 k 0.52 e 0.52
solve/iterate 300
KaLium likes this.
Old   June 9, 2017, 04:29
KaLium's Avatar
Kal-El
Well done!
raise, udf, under relaxation, under-relaxation, underrelaxation
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 15:26
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
should Courant number always be kept below 1? wc34071209 OpenFOAM Running, Solving & CFD 16 March 9, 2014 20:31
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
