source code of UDF for Viscosity function ?
Like Tree1Likes
  • 1 Post By lsqiet
Old   June 5, 2017, 16:48
Default source code of UDF for Viscosity function ?
ali
ebtedaei is on a distinguished road
Hi All,
I want to write a source code of UDF for Viscosity function in mixture model:
y = 3.8 * 0.001003 * (1-(x/0.62))^(-1.55)
Please help me...
Thanks
ebtedaei is offline   Reply With Quote
Old   June 5, 2017, 21:43
jack li
lsqiet is on a distinguished road
#include "udf.h"
DEFINE_PROPERTY(viscosity,c,t)
real x[ND_ND];
real y,a;
C_CENTROID(x,c,t);
a = 1-x[0]/0.62;
y = 3.8*0.001003*pow(a,-1.55);
rerurn y;
KaLium likes this.
lsqiet is offline   Reply With Quote
Old   June 5, 2017, 23:59
ali
Thank you...
you mean is:
return y;
Old   June 6, 2017, 01:28
ali
At the function, the parameter "x" is equal to "volume fraction of particles" in Mixture model.
variation range of x : 20 - 30
How do I define it into the source code?
Old   June 26, 2017, 12:32
ali
please help me...
Old   July 12, 2017, 03:13
ali
Hi All,
I'm using a multi-phase model. I need to write the UDF function for an output variable (derived from two other input parameters of each phase).
But this variable does not exist in the inlet boundary conditions, so I can not add the udf function to its boundary conditions!!!
what should I do? Thank you for advising.
Old   July 12, 2017, 06:41
MayTheFlowBeWithYou's Avatar
I have to remain anonymous, I'm sorry.
Location: The Netherlands, Delft University of Technology
MayTheFlowBeWithYou is on a distinguished road
Maybe you could use a user defined scalar or user defined memory? Need more details to help you.
MayTheFlowBeWithYou is offline   Reply With Quote
Old   July 13, 2017, 01:45
ali
I am using "mixture" multi-phase model and two fluids (Water and X) that Water Viscosity is constant but the X Viscosity is changed.
So Viscosity of the mixture phase is changed and I have to add a viscosity UDF to the inlet boundary conditions.
As mentioned above, this variable does not exist in the inlet boundary conditions, so I can not add the udf function to its boundary conditions!!!
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 14:14
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
