UDF for Real gas model
Like Tree4Likes
  • 1 Post By Kirill-MIPT
  • 2 Post By Kirill-MIPT
Old   June 4, 2017, 09:57
Default UDF for Real gas model
Kirill-MIPT's Avatar
Kirill Borodin
Kirill-MIPT is on a distinguished road
Hello!
I'm trying to load my real gas model to Fluent, but I cannot even make the ideal gas equation of state work, even though I had taken the UDF for it from the User Guide (7.16.5 in the User Guide). For my problem I have P=15000 Pa, T=120 K at the inlet. The proper value of density for this model must be rho~0.436 kg/m3, but Fluent intializes it with value of rho=2.35E-5 kg/m3 in almost all cells and with value of rho~5E+7 kg/m3 in one cell. The process of calculation lasts for 0 iterations with Courant number CN=0.001, then I have:
Divergence detected - temporarily reducing Courant number to 1e-08
and trying again...
Error: Internal error at line 1596 in file '..\..\src\rp_mstage.c'.
Divergence detected in AMG solver
Error Object: #f
I loaded and compiled the library as it was written in the Guide. Could you please help me with this problem?
Regards, Kirill
Svetlana likes this.
Kirill-MIPT is offline   Reply With Quote
Old   June 5, 2017, 03:36
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
Did you study the limitations of that code?
Are you using mass-flow inlet?
KaLium is offline   Reply With Quote
Old   June 5, 2017, 05:07
Kirill Borodin
Yes, I studied all the limitations. The only boundary conditions for my problem are pressure-inlet, pressure-outlet and wall. I also used pressure-based solver.
For my problem the total pressure value is 6E7 Pa and total temperature is 1200 K. This corresponds to hypersonic flow with Mach number M~7. Could this problem type somehow influence the solution process with Pressure-based solver?
Regards
Sent from my C6903 using CFD Online Forum mobile app
Old   June 6, 2017, 20:01
Default Try a pipe first
Svetlana Tkachenko
Svetlana is on a distinguished road
Perhaps you could try the real gas model on a simplified simulation first? For example, create a straight rectangular pipe and try the real gas model in that.
Svetlana is offline   Reply With Quote
Old   June 7, 2017, 17:11
Kirill Borodin
Thank you for your response! I tried a number of simple geometries (a pipe too). Using each of them gave me no results - every time the density field was initialized with inappropriate value in all cells but one (40 vs 0.43 kg/m3) and a VERY inappropriate (maybe it's a junk cell in cell/face array) value of 3e8 kg/m3. The calculation crashed on the first iteration. It seems strange, because I used the same code for ideal gas EOS as it was given in the Guide.
I also tried to run the calculation for a small number of iterations (for example 10) with the built-in ideal gas EOS and after that I turned on the real gas model (that was supposed to model the same gas with the same EOS). I monitored the evolution of static pressure, density, temperature and velocity fields. The temperature field started crashing after the very first iteration. I guess there's something wrong with energy equation? The other fields started crashing some more iterations later (I guess the crashing temperature field influenced them).
Looking forward to your response! Regards
Update: I tried this EOS on three different computers with three different versions of Fluent. There were the same problems
Old   June 8, 2017, 15:55
Kirill Borodin
Thanks to all - I used a code for real gas model for a too early version of Fluent. The code for 15th version differs from it a bit. Now the example model works
Svetlana and KaLium like this.
Old   June 9, 2017, 03:24
Svetlana Tkachenko
Congratulations, that was easy
Old   July 12, 2018, 13:37
Default pls help me
Songyuan Liu
liuso is on a distinguished road
hallo, i have the same Problem , can u tell me , where can i find the new code for 15th Version ?
thanks
liuso is offline   Reply With Quote
Old   September 7, 2018, 08:16
Kirill Borodin
Hello! You may find the code in the User Guide in chapter 7.6.15. The chapter name is User Defined Real Gas Model.
UDF for Multiphase euilerian model pibea FLUENT 3 April 30, 2024 02:25
UDF for improved coal devolatilization model in fluent(devolatilization ) magic0801 Fluent UDF and Scheme Programming 3 May 23, 2023 06:18
How to use the degassing UDF for VOF model in Fluent? qingyang Fluent UDF and Scheme Programming 0 July 11, 2016 13:42
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
how can i model the ideal gas law in CFX? CFX13 CFX 3 July 4, 2013 08:20
