How to keep syntax (decimal places) when writing from array to .txt-file?
Like Tree1Likes
  • 1 Post By sfn
Old   May 29, 2017, 02:53
Default How to keep syntax (decimal places) when writing from array to .txt-file?
Sarah
Sarah_Fluent is on a distinguished road
Hello everybody,
I wrote a UDF where I want to write the temperature values from an Array into a .txt-file:
DEFINE_ON_DEMAND(export__temp)
cell_t c;
Domain *d = Get_Domain(1);
FILE *temp__piece;
real temp1;
Thread *c_thread= Lookup_Thread(d,3);
temp__piece=fopen("temp__piece.txt","w");
begin_c_loop(c, c_thread)
temp1 = C_T(c,c_thread);
fprintf(temp__piece,"%g \n",temp1);
end_c_loop(c, c_thread)
fclose(temp__piece);
The UDF works - but the temperatures do have between 0-3 decimal places. The textfile will be exported and used for Ansys Classic further.
The problem is now: If a temperature has 0 decimal places, Ansys Classic calculates wrong (Temperature that is used then is just 1/100 as high as in the .txt-file). Therefore, I would like Fluent always to use the same number of decimal places (3).
Is that possible and can someone explain me, how this might work?
Kind regards,
Sarah
Sarah_Fluent is offline   Reply With Quote
Old   May 29, 2017, 05:01
sfn
Alexander
sfn is on a distinguished road
use printf format identiffiers
%.3f
KaLium likes this.
sfn is offline   Reply With Quote
Old   May 29, 2017, 08:48
Sarah
It worked out!
Thank you so much
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
