An error occurs after initialized FLuent loaded UDF.
Like Tree1Likes
  • 1 Post By pakk
Old   March 29, 2017, 06:52
Default An error occurs after initialized FLuent loaded UDF.
DENG Weriping
wpdeng is on a distinguished road
1, When I compiled my UDFs, it didn't show any error. But after initialized Fluent, an error occurs.
2, Error: received a fatal signal (segmentation fault).
3, /*My UDF is about the fluid properties depending on temperatures.*/
/* my_density */
#include "udf.h"
double Tm1[2] = {
293.15 ,
294.15
double D[2] = {
0.16632 ,
0.03831
DEFINE_PROPERTY(my_density,c,t)
int i;
double density;
double temp = C_T(c,t);
if(temp <= Tm1[0]) density = D[0];
else if(temp > Tm1[1]) density = D[1];
else
for(i = 0;i <1;i++)
if(temp > Tm1[i] && temp <= Tm1[i+1])
density = D[i] + (temp - Tm1[i]) * (D[i+1] - D[i]) / (Tm1[i+1] - Tm1[i]);
return density;
4, Help me, Please! I really want to solve this problem quickly.
wpdeng is offline   Reply With Quote
Old   March 29, 2017, 08:39
pakk will become famous soon enough
First initialize, then load the UDF.
kmou likes this.
pakk is offline   Reply With Quote
Old   March 29, 2017, 09:01
Default initialize first?
DENG Weriping
My UDF is the properties of the fluid.
If initialize first, how to define the properties?
Old   March 29, 2017, 09:13
That does not really matter, but if possible do something close to your expected result. Define it for example with a uniform density based on a typical temperature in your problem.
Old   March 29, 2017, 11:30
Default Thanks!
DENG Weriping
Really really thank you! I tried the method you told, the fluent can running!
Old   April 6, 2017, 05:46
Default I am also facing the same error
Karthikeyan
kar1209 is on a distinguished road
I am getting the "received a fatal signal (segmentation fault)" error. Is it because the function is not able to access the previous timestep values using F_U_M1 and C_U_M1?
#include"udf.h"
DEFINE_PROFILE(CBC_u_vel,t,i)
real u_f_old, u_c_old, u_temp, u_cor, mass_out = 0, ds;
real x[ND_ND], y[ND_ND];
Thread *nt;
face_t f;
cell_t c, nc;
begin_f_loop(f,t)
mass_out+=F_FLUX(f,t);
end_f_loop(f,t)
u_cor = (20 - mass_out)/20;
begin_f_loop(f,t)
nc = F_C0(f,t);
nt = THREAD_T0(t);
F_CENTROID(x,f,t);
C_CENTROID(y,nc,nt);
ds = x[0] - y[0];
u_f_old = F_U_M1(f,t);
u_c_old = C_U_M1(nc,nt);
u_temp = u_f_old - CURRENT_TIMESTEP*(u_f_old - u_c_old)/ds;
F_PROFILE(f,t,i) = u_temp + u_cor;
end_f_loop(f,t)
The UDF manual says:
Note that data from C_T_M1 is available only if user-defined scalars are defined.
How do I define and use user-defined scalars to access data using C_U_M1 in my program?
Any help would be appreciated.
kar1209 is offline   Reply With Quote
Old   April 6, 2017, 22:41
Default Don't worry about the error!
DENG Weriping
#include"udf.h"
Thread *nt;
face_t f;
cell_t c, nc;
begin_f_loop(f,t)
end_f_loop(f,t)
begin_f_loop(f,t)
nc = F_C0(f,t);
nt = THREAD_T0(t);
F_CENTROID(x,f,t);
ds = x[0] - y[0];
end_f_loop(f,t)
I don't know your UDFs, maybe you can check carefully by yourself.
But if you cannot running the Fluent, you can try the method, which using a constant velocity to initialize the Fluent and then load your UDFs to running the Fluent.
Maybe your problems can be solved. If cannot, you can ask for help to others.
Problem running fluent with udf on batch tobi b. Fluent UDF and Scheme Programming 3 April 14, 2016 14:54
implementing UDF for fluent in workbench for running multiple simulations faizan_habib7 Fluent UDF and Scheme Programming 0 March 18, 2016 23:29
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 11:16
UDF of Zimont model in fluent Z Main CFD Forum 0 February 17, 2005 04:07
