Changing Pressure-inlet to Wall for Inlet valve (from UDF and Scheme)
Like Tree1Likes
  • 1 Post By esco_rep
Old   March 28, 2017, 20:42
Default Changing Pressure-inlet to Wall for Inlet valve (from UDF and Scheme)
steve
esco_rep is on a distinguished road
Hi All,
I'm simulating a simple 'valve bc' to allow a tube to purge after exhausting its high pressure gas. I have used a execute on demand UDF and scheme file which allows the switch between a wall and a pressure inlet once the pressure inside the tube gets below a desired pressure.
When i run the simulation I get a segmentation fault the iteration after the wall switches to pressure inlet. When i call the files/macros manually I have npo issue and it runs fine. Likewise if i continue to run the case after the fault it works as desired.
I am a little stumped as to why, so if someone can shed some light i would appreciate it!
peace
esco_rep is offline   Reply With Quote
Old   March 28, 2017, 22:21
steve
Solving my own question...make sure the updates are set to the same interval as you call the udf/scheme. Always love a simple answer.lol
chaitanyaarige likes this.
Old   December 7, 2024, 06:35
Sarang
sarodesr is on a distinguished road
Hi, I am trying to simulate same problem, can you please share your UDF and Scheme or walk me through how to do that. I am complete new to UDF.
Thanks in advance.
sarodesr is offline   Reply With Quote
boundary conditions, inlet valve, scheme, udf
Is it possible? Changing BC from wall to pressure-outlet with an UDF trigger jayemes Fluent UDF and Scheme Programming 12 October 5, 2018 13:40
Accessing wall clock time from Scheme or UDF Angelo Sozzi FLUENT 2 February 23, 2018 06:03
changing scheme variable with UDF? Wagemakers FLUENT 17 September 30, 2015 15:34
Calling zone name, zone id and total pressure from Fluent scheme to UDF kuldip Fluent UDF and Scheme Programming 2 October 6, 2014 01:23
How to combine UDF and Scheme? ali hemmati Fluent UDF and Scheme Programming 3 March 19, 2011 15:45
