What are the differences between ABS_P(p[c], op_pres) and ABS_P(p[c]) ?
Like Tree2Likes
  • 2 Post By pakk
Old   March 23, 2017, 01:10
Default What are the differences between ABS_P(p[c], op_pres) and ABS_P(p[c]) ?
SJSW is on a distinguished road
Hi~
I found ABS_P(p[c], op_pres) in the example of DEFINE_CAVITATION_RATE in ANSYS Help.
Then I found ABS_P(p[c]) in the description above :
If ABS_P < p_vapor, then
c_evap * rhoV[c] * sqrt(2.0/3.0*rhoL[c]) * ABS(p_vapor - ABS_P(p[c]))
1. What are the differences between ABS_P(p[c], op_pres) and ABS_P(p[c]) ?
2. What is op_pres?
Thanks!
SJSW is offline   Reply With Quote
Old   March 23, 2017, 03:42
pakk will become famous soon enough
The first part ("If ABS_P < p_vapor, then ... ABS_P(p[c])") from the Fluent help is not really UDF code, but is an explanation of what the goal is, but they wrote the equation already in programming code.
But they obviously made a mistake: ABS_P(p[c]) means the absolute pressure, but they forgot op_pres. In the code below, they did not make this mistake.
"op_pres" means operating pressure.
I am happy that you asked this question: until now I used
RP_Get_Float("operating-pressure")
to obtain the operating pressure in my UDFs. But now I see that I could just use op_pres, which should make my code more simple (and a tiny bit faster, but I don't think I will notice that).
SJSW and souza.emer like this.
pakk is offline   Reply With Quote
