UDF Dynamic Meshing for Translation Motion
Like Tree1Likes
  • 1 Post By kywong5
Old   February 24, 2017, 01:08
Default UDF Dynamic Meshing for Translation Motion
kywong5 is on a distinguished road
Hi all,
I have used the simple UDF to prescribe the translational CG motion for a box to move in the x-direction with velocity of 1 m/s. The UDF as below:
#include "udf.h"
DEFINE_CG_MOTION(translational_profile, dt, vel, omega, time, dtime)
real u1 = 1.0;
vel[0] = u1;
vel[1] = 0.0;
vel[2] = 0.0;
My question: Is that possible for me to simulate the box move in the x-direction for 2seconds then continue to move in the opposite direction (Negative x-direction) for another 2seconds?
Thank you!
kywong5 is offline   Reply With Quote
Old   February 24, 2017, 05:29
Kevin
KevinZ09 is on a distinguished road
Sure, time is passed as an argument, so you can use it to specify the motion.
KevinZ09 is offline   Reply With Quote
Old   February 28, 2017, 04:02
Thank you so much, KevinZ09.
Do you have any UDF sample or guideline that defines such movement by using the argument function?
Would you mind to share with me?
Old   February 28, 2017, 04:38
Kevin
I don't have any myself, but there's a pretty good example in the manual, with clear descriptions. So I'd suggest to have a look at that one, and adapt it to your personal needs. Try it, and if it doesn't work, explain what you're trying to do, show your work and give details on the errors you get. Then we can help you further from there.
Old   February 28, 2017, 22:28
Thank you for the guidance, KevinZ09.
I will work on it
Old   March 7, 2017, 05:11
Hi KevinZ09, my problem has been solved with time argument. Thank you
Old   April 19, 2017, 05:35
Ninh
ninhtran is on a distinguished road
HI Kywong,
I also working on moving a solid sphere with a velocity of 0.1m/s. The sphere should move upwards (due to the boyancy force) but in experiment, the rising velocity of the sphere is controlled by hand so it rises with 0.1m/s upwards. Can you please guide me how to set up the simulation?
Thank you,
Ninh
ninhtran is offline   Reply With Quote
Old   April 24, 2017, 09:22
Hi Ninhtran,
I assume you want to move the sphere in +y-direction. Do correct me if I'm wrong.
You may prescribe 0.1m/s in +y-direction and 0m/s in x-direction or z-direction.
In case you want to stop the movement after some time, you may use time argument to control it
Regards,
kywong5
Old   April 24, 2017, 17:08
Ninh
Hi Ninhtran,
Regards,
kywong5
Hi Kywong,
Yes, you are absolutely right. Does your simulation work? How did you solve the time argument? I will work on the CG translational movement, because sofar I only tried with 6DOF UDF so i dont know how to set up with CG Movement.
Thank you for your kind reply!
Old   April 25, 2017, 03:13
Hi Ninhran,
Yes, it works. I'm using the dynamic mesh and UDF to prescribe the CG translational movement.
You are most welcome.
ninhtran likes this.
Old   June 17, 2017, 23:36
Charles
Charlesdupumping is on a distinguished road
Please can you show your time argument UDF ... PLEASE
Charlesdupumping is offline   Reply With Quote
Old   June 17, 2017, 23:39
Charles
Hi Ninhran,
Please can you show your time argument UDF. Thanks
Old   June 15, 2019, 18:42
ahmed
ahmed fahmy is on a distinguished road
please can you send the udf code urgently
ahmed fahmy is offline   Reply With Quote
Old   November 22, 2019, 02:34
m.reza
m.reza is on a distinguished road
Please send me the udf.
I have a membrane and its movement in y direction is a function of x and z positions.
m.reza is offline   Reply With Quote
Problem with UDF for CG Circular Motion luthlau Fluent UDF and Scheme Programming 1 September 16, 2016 03:08
DYNAMIC MESH udf for orbiting motion. avidash Fluent UDF and Scheme Programming 3 March 4, 2015 11:58
UDF for dynamic meshing? prasaddeole FLUENT 2 October 6, 2014 12:55
code in dynamic meshing udf wlt_1985 FLUENT 3 April 21, 2011 15:33
Problem related with UDF for dynamic mesh Ryan FLUENT 6 April 29, 2004 10:29
