properties change with volume fraction
Like Tree3Likes
  • 1 Post By pakk
  • 1 Post By pakk
  • 1 Post By pakk
Old   February 10, 2017, 19:36
Lightbulb properties change with volume fraction
ali sarlak
a_Sarlak is on a distinguished road
hi dear friends
i work on nanofluid using mixture model of fluent.
i want to change viscosity using volume fraction so i need udf.
can any body help me, i really need it.
thanks
a_Sarlak is offline   Reply With Quote
Old   February 13, 2017, 05:30
pakk will become famous soon enough
Look in the Fluent manual for something similar, think about what should be changed, and come here for help to change it.
a_Sarlak likes this.
pakk is offline   Reply With Quote
Old   February 13, 2017, 08:00
ali sarlak
dear pakk thanks for your respond.
my cod is:
#include "udf.h"
DEFINE_ADJUST(viscouse_function, d)
real vf;
real visc;
cell_t cell;
Thread **pt;
Thread *cell_threads;
Domain *mixture_domain;
mp_thread_loop_c(cell_threads, mixture_domain, pt[1])
begin_c_loop(cell,pt[1])
vf=C_VOF(cell,pt[1]);
visc = vf; /*it just example*/
end_c_loop(cell,pt[1])
but it doesnt work.
i want to change viscosity with volume fraction
did i do a mistake?
thanks
Old   February 13, 2017, 08:28
but it doesnt work.
Can you be more specific? What makes you say that it doesn't work? Does it crash? Does it give wrong results?
Old   February 13, 2017, 11:44
ali sarlak
there is no error when interpret in fluent but when i initialize it says:
Node 0: Process 11020: Received signal SIGSEGV.
Node 1: Process 10652: Received signal SIGSEGV.
Node 2: Process 9056: Received signal SIGSEGV.
Node 3: Process 4044: Received signal SIGSEGV.
Node 4: Process 10068: Received signal SIGSEGV.
Node 5: Process 5768: Received signal SIGSEGV.
Old   February 13, 2017, 12:01
If it is during initializating, then your problem could be a physics problem, not a programming problem.
You are saying in the UDF that viscosity is proportional to the volume fraction. When you initialize, the volume fraction is probably initialized at zero. So you are asking Fluent to initialize a fluid with zero viscosity (a superfluid). Fluent is not made to do that.
Try an equation that will make viscosity not equal to zero, for example:
visc = 0.000008+vf*0.000001;
Old   February 13, 2017, 12:31
ali sarlak
thanks again
i just do it but the error still remain.
mixture, properties, udf, volume fraction.
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Difference between Volume Fraction and Mass Fraction in CEL foo7 CFX 0 September 21, 2011 09:45
interDyMFoam - change in volume fraction gopala OpenFOAM Running, Solving & CFD 0 April 27, 2009 11:46
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
the Eulerian model and the lower volume fraction hx li FLUENT 2 October 27, 2005 07:17
