where in manuals I may read about whole procedure of using UDF? |
February 9, 2017, 15:49 |
Serguei
Rep Power: 11 |
Hello people!
I am new in UFD. I need to include the electric fields applied on the ions and search they trajectories in combined influence - flow and electric field. The electric fields would be precalculated, using another software. I would like to know about whole procedure of working with UDF. Where I need to write the code? How to compile and execute it? Where I should keep the files with precalculated electric fields? In what format they should be written? How I can call them? I would be very appreciate if you refer me where I may read that in the simplest form (chapters in ANSYS FLUEN manuals, etc.) |
February 10, 2017, 04:42 |
#2 | ||
Rep Power: 10 |
Hi Serguei,
I'm also new to the UDF domain. I'm currently working on a problem which looks similar to yours (I'm working with an magnetic field instead of a electric field). Quote:
Regarding the compiling and the other things you ask I'm clueless. Hope it will help, and sorry for my bad english. Tim |
February 10, 2017, 05:45 |
#3 | |
Kevin
Rep Power: 10 |
February 10, 2017, 18:20 |
Serguei
Rep Power: 11 |
thank you very much!
February 10, 2017, 18:21 |
Serguei
Rep Power: 11 |
thank you!
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 11:52 |
UDF Compiling - can't read ..\..\src\xxx_udf.c: No such file or directory | willy | Fluent UDF and Scheme Programming | 0 | March 28, 2013 12:22 |
Read profile file from UDF | DonQuijote | Fluent UDF and Scheme Programming | 0 | February 18, 2013 12:56 |
UDF to read data from a file for VOF model | Pablo | FLUENT | 0 | October 23, 2008 08:02 |
UDF to read and write data | Mcgregor | FLUENT | 4 | June 9, 2003 14:21 |
