Creating a UDF for fluid inlet velocity
Like Tree1Likes
  • 1 Post By pakk
Old   February 8, 2017, 09:05
Default Creating a UDF for fluid inlet velocity
AMEET KUMAR
ameetks99 is on a distinguished road
I am new in ansys, I don't know how to write a UDF.
Please can someone help me to write a UDF for fluid inlet velocity in recipricating pump which is rotating at 1450 rpm and total displacement of piston is 20 mm.
Diameter of piston is 14 mm.
ameetks99 is offline   Reply With Quote
Old   February 8, 2017, 09:34
pakk will become famous soon enough
If you don't know how to start a udf, I would start by looking in the manual. Try if you can find a udf that does something similar, and think if you can figure out what should be changed. Change that in the code, as good as you guess/understand how that should be done.
Your first attempt will probably not work. Then post it here, so we can see how you are thinking, and can really assist you to learn how to make UDFs.
ameetks99 likes this.
pakk is offline   Reply With Quote
Old   February 9, 2017, 00:10
AMEET KUMAR
thank you for reply
But udf for sinusoidal velocity is not there in manual, if you have a udf for sinusoidal velocity please send it to me.
Old   February 9, 2017, 00:25
AMEET KUMAR
#include "udf.h"
DEFINE_PROFILE(unsteady_velocity, thread, position)
face_t f;
real t = CURRENT_TIME;
begin_f_loop(f, thread)
F_PROFILE(f, thread, position) =2.61*sin(152*t);
end_f_loop(f, thread)
I tried this udf but inlet velocity is showing ZERO,
Old   February 9, 2017, 03:59
And do you get any warnings when you compile or run?
I don't remember now if the sine function works by default, otherwise you have to add
#include <math.h>
to your code. But then you should have seen a warning like "undefined reference to sin"...
Old   February 9, 2017, 06:36
AMEET KUMAR
cpp -I"C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.0/src" -I"C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.0/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.0/client/src" -I"C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.0/multiport/src" -I. -DUDF
ONFIG_H="<udfconfig.h>" "C:\Users\Ameet Kumar Singh\Desktop\piston pump h\udf.h.c"
C:\\Users\\Ameet Kumar Singh\\Desktop\\piston pump h\\udf.h.c:2: math.h: No such file or directory
This message is showing when I added #include "math.h" and I interpret it
Old   February 9, 2017, 07:02
Go back to your original UDF, but now in a foldername that has no spaces.
There are four spaces in the name of this folder, and Fluent is known to have problems with that.
Old   February 9, 2017, 07:16
AMEET KUMAR
ONFIG_H="<udfconfig.h>" "D:\\udf.c"
D:\\\\udf.c:2: math.h: No such file or directory
the problem remain same when I copy the udf file to a drive
Old   February 9, 2017, 07:19
That is impossible, because your original UDF did not have any reference to math.h in it.
Old   February 9, 2017, 07:21
AMEET KUMAR
If you can write the udf for inlet velocity of reciprocating pump which is rotating at 1450 rpm and movement of the piston is 20 mm It will be helpful for me
Old   February 9, 2017, 07:29
Try this:
#include "udf.h"
face_t f;
If you could read answers that people gave you, it would be helpful for yourself.
how to put udf inlet velocity and udf outlet pressure in fluent raminostadi Fluent UDF and Scheme Programming 4 July 3, 2017 07:43
UDF for Inlet velocity Mijin Kim FLUENT 0 September 28, 2009 05:50
Urgent! Help on UDF to set inlet velocity Ray Hong FLUENT 4 December 30, 2005 13:32
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 12:21
UDF paraboloid velocity inlet Ronak Shah FLUENT 0 June 4, 2003 10:44
