Assigning material to wall using scheme command
Like Tree2Likes
  • 1 Post By pakk
  • 1 Post By pakk
Old   January 27, 2017, 09:12
Default Assigning material to wall using scheme command
Kushal Puri
Kushal Puri is on a distinguished road
I want to assign a material to wall using the scheme command. Anyone worked on it.
Thanks
Kushal Puri is offline   Reply With Quote
Old   January 31, 2017, 04:51
pakk will become famous soon enough
Find out what you need to type in the text user interface.
Probably something like "//define/boundary-conditions/wall", and then look at the answers that you have to type in Fluent.
Then put everything in one line. "//define/boundary-conditions/wall answer-1 answer-2 answer-3 ... answer-n"
Check if that works by typing this line (without the quotation marks) into Fluent.
If that works, you can also put this in scheme in this way:
(ti-menu-load-string "your text here")
Kushal Puri likes this.
pakk is offline   Reply With Quote
Old   January 31, 2017, 06:23
Kushal Puri
Thanks for the reply, i already tried this but this is the lengthy procedure, i am looking for the some scheme command that should do this in single step.
Thanks for your concern.
Old   January 31, 2017, 06:39
My procedure will give you a scheme command that will do it in a single step.
You probably want to see something like
(set-wall-material 'bottomwall 'plastic)
As far as I know, it is not implemented in Fluent directly (but I could be wrong, and would like to hear that!). You can define it yourself:
(define set-wall-material (lambda (wallname material) (ti-menu-load-string (format #f "//define/boundary-conditions/wall ~a ,,, ~a ,,," wallname material))))
After fixing the command above (I probably guessed the wrong number of comma's, and am likely to have some parentheses wrong), this will work.
But what would you gain by doing that?
Old   January 31, 2017, 12:03
Kushal Puri
Thanks dear for the suggestion. I got the command
(send (get-thread 2) set-var! 'material "steel")
where 2 is my thread id and steel is my material.
Old   January 31, 2017, 12:10
Okay, thank you very much for sharing your answer! Now I want to find out what the 'send' really does...
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
