Using UDF to define parameter
Like Tree2Likes
  • 2 Post By kirmaks
Old   January 24, 2017, 03:00
Question Using UDF to define parameter
Oleg Vlasov
Oleg V. is on a distinguished road
Dear friends!
I am trying to solve transient problem. For my case I need to specify time-depended gravity, but I don't know how to do it. The only thing that I can specify for gravity is parameter. That's why my question is: how can I define the value of the parameter in UDF?
I mean that the value for gravity will be changed in each time step (using real t = CURRENT_TIME).
Oleg
Oleg V. is offline   Reply With Quote
Old   January 24, 2017, 03:23
KirMaks
kirmaks is on a distinguished road
Hallo, You can replace Your gravity with the source in NS equations and then use source UDF to change the gravity vector with time as it is described here:
UDF to modify gravity via M_gravity[ND_ND] or DEFINE_ADJUST
Best regards, Maksim
pakk and Oleg V. like this.
kirmaks is offline   Reply With Quote
Old   January 24, 2017, 03:55
Oleg Vlasov
kirmaks,
Thank you so much!
That's exactly what I need! It helped me to define all gravity components!
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
Please help UDF error!!!! dinhanh Fluent UDF and Scheme Programming 3 September 26, 2014 05:10
How to use UDF to define a moving wall lingo FLUENT 9 August 19, 2014 10:14
use of pointers in specific heat udf mdakbari Fluent UDF and Scheme Programming 0 April 18, 2014 12:37
UDF problem libia87 Fluent UDF and Scheme Programming 1 May 4, 2012 22:49
