Saving Value of Surface Integral
Like Tree1Likes
  • 1 Post By Kushal Puri
Old   December 12, 2016, 18:10
Default Saving Value of Surface Integral
Liam111
bigbird142 is on a distinguished road
Hello All,
I am attempting to find the value of a surface-integral and store it to a variable. (I would prefer an answer using Journal however is it is only possible in Scheme then I will work with that).
So far I have tried:
(define machnum1 ("/report/surface-integrals/mass-weighted-avg 13 , mach no"))
I get an error:
Error: eval: invalid function
Error Object: "/report/surface-integrals/mass-weighted-avg 13 , mach no"
Any help with this would be highly appreciated!
bigbird142 is offline   Reply With Quote
Old   December 13, 2016, 02:35
Kushal Puri
Kushal Puri is on a distinguished road
Originally Posted by liamheidt View Post
Hello All,
I get an error:
(define (machnum1)
(pick-a-real"report/surface-integral/mwa (13) mach no"))
bigbird142 likes this.
Kushal Puri is offline   Reply With Quote
Old   December 13, 2016, 07:05
Liam111
Originally Posted by Kushal Puri View Post
(define (machnum1)
Thank you Kushal! Your help is appreciated!
I thought this would be enough, however I am running into a second issue.
Basically I am trying to determine if the Mach number is greater than 1 and depending if it is or isn't change the cfl number.
I have done:
(if (> machnum1 1) (ti-menu-load-string "/solve/set/courant-number/10") (ti-menu-load-string "/solve/set/courant-number/100"))
However it doesn't seem to be working, as "machnum1" is not an value (I should have specified I required this in numerical form in my original question - apoligies)
I really have no clue where to go from here.
Again, any help would be greatly appreciated!
Cheers
Old   December 13, 2016, 10:23
Liam111
I have done:
Cheers
I have found the solution:
(define machnum1(string->number (pick "/report/surface-integrals/mass-weighted-avg (11) mach-number")))
This will create machnum1 as a double and allow one to use it in standard operations.
fluent, journal, scheme
Surface integral on only part of a surface? nathanblank ANSYS 2 January 23, 2022 07:39
new-parameter :surface integral of velocity nenazarian Fluent UDF and Scheme Programming 1 December 6, 2013 03:16
[snappyHexMesh] Snap Precision to a STL Surface malaboss OpenFOAM Meshing & Mesh Conversion 16 July 26, 2013 02:44
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
Surface Integral - Mass Flow Rate Venkatesh V FLUENT 3 October 10, 2008 17:18
