Using DEFINE_CG_MOTION and Specifying the Angular Velocity for a Certain Axis |
November 7, 2016, 19:09 |
Joshua
Rep Power: 12 |
You can set the angular velocity of a solid body using the macro DEFINE_CG_MOTION(UDF_name,dt,vel,omega,time,dtime) and specifying the values of angular velocity about the 3 main axes (x,y, and z) by returning a value to omega[0] etc.
Is there a way to specify an angular velocity about another axis? |
December 15, 2016, 02:29 |
xabi
Rep Power: 11 |
Hi Joshua,
If I am not wrong, you can specify the axis of rotation when you create the specific dynamic mesh zones. Under the rigid body you have to introduce the center of gravity location. |
dynamic mesh, fluent, udf |
