Fluent UDF implementation of a 1D wave equation (Convective BC) at an outlet
Like Tree1Likes
  • 1 Post By balav94
Old   September 17, 2016, 08:30
Default Fluent UDF implementation of a 1D wave equation (Convective BC) at an outlet
Bala
balav94 is on a distinguished road
Hi everyone!
I am working on a premixed combustion problem using the 'Species transport' Combustion model in Fluent. I realized that the available pressure outlet BC in Fluent does not work well for my problem, since using this leads to really high maximum pressure prediction at a point close to the outlet (pressure time history is used to compare with the experimental results). I have checked all other BCs.
So, in order to tackle this, I found that a PLANE WAVE or 1D wave equation for pressure might work, based on an extensive Literature survey. However, I am a beginner at writing UDFs and wasn't able to find any examples as such in the Fluent UDF guide.
So, it would be really nice if someone could guide me to how to write a UDF for a PLANE WAVE/Convective BC for pressure at Outlet. In case someone has already written a similar UDF and is willing to share, that would also be great.
Thanks in advance!
afzal zahiri23 likes this.
balav94 is offline   Reply With Quote
UDF to adjust pressure outlet a.lynchy FLUENT 4 February 15, 2021 01:50
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Wave equation for hfss in fluent jpcfd FLUENT 0 March 16, 2010 11:45
what is the condition to use the wave equation? mmff Main CFD Forum 0 January 26, 2010 05:25
UDF in Fluent to Match Mass Flow at Pressure Outlet Jonas Larsson Main CFD Forum 1 April 29, 1999 11:44
