how to put udf inlet velocity and udf outlet pressure in fluent
Like Tree3Likes
  • 1 Post By D.M
  • 1 Post By raminostadi
  • 1 Post By KaLium
Old   September 11, 2016, 11:35
Red face how to put udf inlet velocity and udf outlet pressure in fluent
ramin
raminostadi is on a distinguished road
hello experts
I am beginer in ansys fluent
I am working on pulse blood flow in an artery. my boundry conditions are
parabolic velocity in inlet and parabolic pressure in outlet.
when I want to interpret my udfs for velocity and pressure, I can not put both
of them simultaneously and fluent considere my last imput file.
now I want to know how can I put udf inlet velocity and udf outlet pressure in
fluent simultaneously؟
best regards
raminostadi is offline   Reply With Quote
Old   September 12, 2016, 01:40
D.M
Davoud Malekian
D.M is on a distinguished road
Hello Ramin,
when you want to compile udfs, it is possible to compile your c files seperately,
but in the case of interpreting you can interpret just 1 c file!, so write all of your udfs in 1 c file and then interpret your c file.
raminostadi likes this.
D.M is offline   Reply With Quote
Old   September 12, 2016, 05:12
ramin
Originally Posted by D.M View Post
Hello Ramin,
Thank you so much
D.M likes this.
Old   June 29, 2017, 15:37
ashraf elkotb
ashraf elkotb is on a distinguished road
can I write simple C code definning pressure function without udf.h and use it in fluid solution as a boundary condition ???
ashraf elkotb is offline   Reply With Quote
Old   July 3, 2017, 07:43
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
Fluent always has the udf.h. You don't need to add it to your lib/folder.
Just add the #include udf.h
in your code.
ATIKADAR likes this.
KaLium is offline   Reply With Quote
problem with udf
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 07:45
negative input for velocity inlet to make an outlet? Sipher FLUENT 1 June 24, 2015 03:51
UDF: Change boundary condition. Velocity inlet to pressure inlet at time "t" jpina FLUENT 10 April 11, 2015 15:19
UDF profile: Fluent method for coupling inlet and outlet I-mech Fluent UDF and Scheme Programming 0 May 10, 2014 11:36
UDF to set velocity and pressure in inlet GerardX89 Fluent UDF and Scheme Programming 0 July 16, 2012 11:15
