How to move mesh node perpendicular to the mesh surface |
August 19, 2016, 11:39 |
Subrat
Rep Power: 10 |
I want to move surface nodes perpendicular to the neighbouring surface, could you please suggest how to do it using fluent UDF. Regards Subrat |
August 23, 2016, 10:07 |
KirMaks
Rep Power: 10 |
Hello Subrat,
You may use the face area vector F_AREA to get the direction of the face normal. You will probably need to identify the face by its ID and divide the area vector by its magnitude (NV_MAG) to get the unity normal. The UDF guide and this forum have examples of this. Regards, Maks. |
November 10, 2016, 00:42 |
Subrat
Thank you Maks.
I got the idea and implemented. Regards Subrat |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh | sc.park | OpenFOAM Meshing & Mesh Conversion | 1 | March 13, 2016 14:28 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
