UDF to get the average temperature of a face and use it to define a property |
August 11, 2016, 10:38 |
Gonzalo
Rep Power: 11 |
Dear all,
I have been reading this forum for a while, but this is my first post, so first I would like to say hi. I have been using Fluent for my research during the last 3 years and this forum has provided me with invaluable resources and answers, so thanks to all the contributors. I would like to kindly ask for some help with a UDF that I am trying to write. I am modelling the melting of a material into an enclosure by means of the enthalpy porosity approach. It is a transient, 2D axisymmetric simulation. What I want to do by the UDF is to define an effective thermal conductivity of a material as a function of the Rayleigh number. This Rayleigh number is at the same time a function of the average temperature of one of the walls in the previous time step. I know how to use the DEFINE_PROPERTY macro, but my problem is that I don’t know how to retrieve the average temperature of the wall from the previous time step. Thus, I decided first to write a Define on Demand macro in order to learn how to retrieve that average temperature. What I do is to run the simulation for a couple of time steps and then execute the macro on demand. This way I can compare the temperature that I want to retrieve by the UDF with the actual temperature of the wall. If this would work, then I could implement this part of the code in the DEFINE_PROPERTY macro….but obviously, I have facing some problems. The UDF that I have written is shown next: #include "udf.h" DEFINE_ON_DEMAND(demo_calc) { Domain *d; face_t f; real tavg; real temper; real vol_tot; real volume; int ID=7; /*this is the ID of the boundary wall that I want to get the temperature from*/ Thread *t; cell_t c; d = Get_Domain(1); t = Lookup_Thread(d,ID); thread_loop_c(t,d) { begin_c_loop(c,t) { volume = C_VOLUME(c,t); /* get cell volume */ temper = C_T(c,t); /* get cell temperature */ vol_tot += volume; tavg += temper*volume; } end_c_loop(c,t) tavg /= vol_tot; printf("temp = %g\n",tavg); } } I can interpret and execute the udf, however, instead of one temperature I get 8 different temperatures, as can be seen below: (Note that in the model I have 8 bc in total, which I guess that is not just a coincidence) temp = -1.#IND temp = -1.#IND temp = 562.851 temp = 1.4915e+06 temp = 559.15 temp = 1.63967e+06 temp = 559.15 temp = 1.41307e+06 The temperatures of 559 and 562K are in the range of the working temperatures of the model. However they don’t match the temperature of the wall that I am looking for. I have tried different codes and I have checked the manual and the forum looking for answers…but I wasn’t able to reach any solution. So any help would be really appreciated. Thank you very much in advance, Gon |
August 12, 2016, 06:04 |
Davoud Malekian
Rep Power: 10 |
first of all you have identified your thread by t = lookup_thread(d,id) and your id is 7 , so what is the reason you are looping over the threads?? (thread_loop_c(t,d)!!) , i mean if you have identified t , then there is no need to do that , just looping over faces would be enough!! and by faces i realy mean exactly the "faces"!! your thread is a face thread not cell thread so why looping over cells?? and what do the lines "tavg += temper*volume; & tavg /= vol_tot;" mean?? maybe try this : #include "udf.h" static real area_tot = 0; static real tsum = 0; static int i = 0; DEFINE_EXECUTE_AT_END(average_temp) { Domain *d; face_t f; real A[ND_ND]; real temper; real area; int ID=7; Thread *t; cell_t c; d = Get_Domain(1); t = Lookup_Thread(d,ID); begin_f_loop(f,t) /*you have identified t in previous steps*/ { i++; F_AREA(A,f,t); area = NV_MAG(A); temper = F_T(f,t); area_tot += area; tsum += temper; } end_f_loop(f,t) F_UDMI(f,t,0) = tsum /( i * area_tot); } this udf that i have written gives you the average temp on the wall at the end of each time step: (average temp of your face/area of your face) , if you want something else try to change the udf. so now you have average temperature at the end of each time step (in UDMI) and you can use it for next time step! do not forget to go to "define" , "user define" , "memory" and change the number of "user define memory locations" into 1. i haven't checked the udf myself but this was as far as i could help i think i hope it helps u. Last edited by D.M; August 13, 2016 at 01:53. |
August 12, 2016, 07:11 |
Davoud Malekian
Rep Power: 10 |
another thing if you insist on finding the cells temp and ... cause i think you need them for DEFINE_PROPERTY , you should do something like this:
#include "udf.h" static real vol_tot = 0; static real tsum = 0; static int i = 0; DEFINE_EXECUTE_AT_END(average_temp) { Domain *d; face_t f; real temper; real volume; int ID=7; Thread *t; Thread *t0; cell_t c; cell_t c0; d = Get_Domain(1); t = Lookup_Thread(d,ID); begin_f_loop(f,t) /*you have identified t in previous steps*/ { i++; c0 = F_C0(f,t); t0 = THREAD_T0(t); temper = C_T(c0,t0); volume = C_VOLUME(c0,t0); vol_tot += volume; tsum += temper; } end_f_loop(f,t) C_UDMI(c0,t0,0) = tsum /( i * vol_tot); } i don't know if it is right or not but you can check it your self and try to change it if you think it is wrong. |
August 13, 2016, 05:13 |
Gonzalo
Rep Power: 11 |
Hi D.M,
Many thanks for the help! I have been doing some tests and I think that your code can definitely help me. However, it gives an error while running. After some trials, I saw that this is solved if I the F_UDMI statement is moved within the "begin_f_loop". I have read that UDM is associated with cells, and thus it needs a loop when it is used. I concluded that this might be the reason for the error. Anyway, I have realized that this probably doesn’t affect my UDF. Since my objective is just to compute one temperature value (the average temperature of the boundary wall with ID = 8), I guess that I don’t need to use the UDM. I just need to write a UDF where that average temperature is a global variable. The value of this global variable is calculated at the end of each time step by the DEFINE_EXECUTE_AT_END macro, and used in the DEFINE_PROPERTY macro as an input. I used your code and I did some modifications to get the average value of the boundary wall at the end of each time step (see it at the end of the message). The tavg value is the one that will be used in the DEFINE_PROPERTY macro. The code is running…but now I have another problem: I get 4 different tavg values instead of one!! You can see it in the results attached below (I get them by means of the TUI). The funny story is that if I take the value of the 3 results that have physical meaning and calculate their average, then I get the average temperature that I am looking for. However, when I use the variable tavg to calculate the thermal conductivity in the DEFINE_PROPERTY macro I get also different values of thermal conductivity. It looks as if the wall with ID 8 would be divided into different zones at the same time... Tavg = -1.#IND area_tot = 0 Tavg = 582.391 area_tot = 0.0723761 Tavg = 559.15 area_tot = 0.0652473 Tavg = 559.15 area_tot = 0.0720006 I have tried several alternatives but I don’t get the solution. I thought that it might be related with the fact that the model is axisymmetric…but I used it on a 2D planar model and I got the same 4 results. .. Any help is really appreciated Thank you!! Gon P.S.: I started working with UDFs a few days ago...so I apologize if any of the things that I'm saying they make no sense... Code: #include "udf.h" real tavg; DEFINE_EXECUTE_AT_END(average_temp) { Domain *d; face_t f; real temper = 0.0; real A[ND_ND]; real area = 0.0; real area_tot = 0.0; int ID = 8; /*this is the ID of the boundary wall that I want to get the temperature from*/ Thread *t; int zone_ID; d = Get_Domain(1); t = Lookup_Thread(d,ID); tavg = 0.0; begin_f_loop(f,t) { F_AREA(A,f,t); area = NV_MAG(A)*2.0*M_PI; /*Since the model is axisymmetric, we have to multiply by 2pi*/ area_tot += area; temper = F_T(f,t); tavg += temper*area; } end_f_loop(f,t) tavg /= area_tot; printf("Tavg = %g area_tot = %g\n",tavg,area_tot); } DEFINE_PROPERTY(thermal_conductivity,c,t) { real keff; real Ra; real Nu; real k = 0.55; real C = 0.03; real n = 0.25; real beta = 0.0005; real Tm = 565.00; real v = 0.000002; real alfa = 0.0000005; real g = 9.81; real Lc = 0.33333; Ra=(g*beta*(tavg-Tm)*pow( Lc, 3))/(v*alfa); Nu=C*pow( Ra, n); keff = k*Nu; return keff; } |
August 15, 2016, 00:33 |
Gonzalo
Rep Power: 11 |
Hi all,
I have found that the reason why I got several results instead of 1 was that I was running the simulation in a parallel mode, so the mesh was partitioned. When I changed to a serial mode, then I got only one result and the code is working properly. Hopefully this info can be useful to other people. Cheers, Gon |
August 18, 2016, 16:35 |
Davoud Malekian
Rep Power: 10 |
thank u so much for posting the reason, i was wondering what the reason could be, tnx.
March 15, 2018, 04:31 |
Cna
Rep Power: 12 |
Dear all
Since fluent divides computational domain when running in parallel mode, sometimes you need to be aware of some udf coding consideration. For example, when you are going to compute total volume of all grid and fluent give you n (number of assigned processor) output. Fortunately, by a little manipulation in your udf you will be able to make it suitable for parallel simulation. For this, refer to chapter entitled parallel considerations in udf manual. Or below link: Parallel UDF Problem |
August 31, 2019, 12:04 |
Hamza Latif Mehr
Rep Power: 7 |
Hey,
I was working on a code related to this and i found your code and basically i want to change the inlet velocity or temperature if possible with the cell ID's temperature. The code is this. #include "udf.h" real tavg; DEFINE_EXECUTE_AT_END(average_temp) { Domain *d; face_t f; real temper = 0.0; real A[ND_ND]; real area = 0.0; real area_tot = 0.0; int ID = 78; /*this is the ID of the boundary wall that I want to get the temperature from*/ Thread *t; int zone_ID; d = Get_Domain(1); t = Lookup_Thread(d,ID); tavg = 0.0; begin_f_loop(f,t) { F_AREA(A,f,t); area = NV_MAG(A)*2.0*M_PI; /*Since the model is axisymmetric, we have to multiply by 2pi*/ area_tot += area; temper = F_T(f,t); tavg += temper*area; } end_f_loop(f,t) tavg /= area_tot; printf("Tavg = %g area_tot = %g\n",tavg,area_tot); } DEFINE_PROFILE(velocity_magnitude, t, i) { real velocity; face_t f; if ((tavg>=305)) { velocity=3; } if ((tavg<305)) { velocity=1.5; } begin_f_loop(f,t) { F_PROFILE(f,t,i) = velocity; } end_f_loop(f,t) } It is interpreted, and entered as udf inlet velocity but nothing happens rather the velocity becomes constant at 0.9 ms-1 (Strange since i've put 3 and 1.5 velocities in the code. What's wrong and how should i execute it? |
September 2, 2019, 01:46 |
#9 |
Alexander
Rep Power: 34 |
did you hooked DEFINE_EXECUTE_AT_END macro and your define_profile as inlet boundary condition?
DEFINE_EXECUTE_AT_END: fluent GUI -> user defined -> function hooks -> execute at end define_profile : fluent GUI -> boundary conditions -> your inlet _. velocity change from constant to your udf best regards |
September 2, 2019, 05:17 |
#10 |
Hamza Latif Mehr
Rep Power: 7 |
Thank you! I'll try this.
September 2, 2019, 05:45 |
#11 |
Hamza Latif Mehr
Rep Power: 7 |
Hey, Thank you for replying.
I did hook up and put in the boundary conditions; the two functions like you said, It is giving error: recieved a fatal signal (segmentation fault) Error Object: #f I'll try to change some things and execute it. If you could identify the problem, it would be great. The problem is with in DEFINE_EXECUTE_AT_END function. I ran both functions separately and this gave the segmentation fault. Best regards Last edited by hlmehr; September 2, 2019 at 16:08. Reason: More information |
September 3, 2019, 03:48 |
#12 |
Alexander
Rep Power: 34 |
#include "udf.h" real tavg=300; best regards |
September 9, 2019, 03:41 |
#13 | |
Vignesh Lakshmanan
Rep Power: 10 |
Sorry for restarting the thread. I am simulating flow through a capillary tube (3D) in Fluent and I would like to understand the variation in temperature and pressure across the length of the capillary. The simple and tedious option would be to create multiple faces across the capillary (varying in 2 directions, say x and y) and report values at each face. Is it possible to do this through UDFs? I would like inputs in looping through cells in a particular domain and write values at fixed intervals, say 0.1 m or so PS: My geometry is a coiled capillary Thanks in Advance!!! |
September 25, 2019, 07:05 |
UDF to get the average temperature of two faces and use them to defin
#14 |
Ram Kumar Pal
Rep Power: 11 |
hi,
I am working on the udf to define a property based on the temperature of two different faces (annulus ). The UDf I am trying to use is #include "udf.h" real tavg_glass; real tavg_abr; /*averge glasscover innerwall temperature*/ DEFINE_EXECUTE_AT_END(averagetempglasscoverinnerwa ll) { Domain *d; face_t f; real A[ND_ND]; real area_g = 0.0; real area_tot_g = 0.0; int ID = 8; /*this is the ID of the boundary wall that I want to get the temperature from*/ Thread *t; int zone_ID; d = Get_Domain(1); t = Lookup_Thread(d,ID); tavg_glass = 0.0; begin_f_loop(f,t) { F_AREA(A,f,t); area_g = NV_MAG(A); area_tot_g += area_g; tavg_glass += F_T(f,t)*area_g; } end_f_loop(f,t) tavg_glass /= area_tot_g; printf("average glass cover temp = %g area_tot_g = %g\n",tavg_glass,area_tot_g); } /*averge absorber outerwall temperature*/ DEFINE_EXECUTE_AT_END(averagetempabsorberouterwall ) { Domain *d; face_t f; real A[ND_ND]; real area_a = 0.0; real area_tot_a = 0.0; int ID = 9; /*this is the ID of the boundary wall that I want to get the temperature from*/ Thread *t; int zone_ID; d = Get_Domain(1); t = Lookup_Thread(d,ID); tavg_abr = 0.0; begin_f_loop(f,t) { F_AREA(A,f,t); area_a = NV_MAG(A); area_tot_a += area_a; tavg_abr += F_T(f,t)*area_a; } end_f_loop(f,t) tavg_abr /= area_tot_a; printf("Tavgabrouterwall = %g area_tot_a = %g\n",tavg_abr,area_tot_a); } /*calculation of the property on the basis of the temperature*/ DEFINE_PROPERTY(thermalconductivity,c,t) { real keff; real lamda; real pressure= 0.0001; /*annulus gas pressure (mmhg=torr=10^-4)*/ real delta = 3.53*pow(10,-8); /*molecular diameter of annulus gas (cm)*/ real Tavg; /* degree calcius*/ real b=1.571; /* interactio coefficient*/ real gamma=1.4; /* ratio of specific heats for the annulus gas*/ real a; /* accomodation coefficient*/ real dia_absorber=0.07; /* absorber tube diameter*/ real dia_glass=0.109; /* glass cover inner diameter*/ real k_air=0.02551; /*normal conductivity*/ Tavg=(tavg_abr+tavg_glass)/2; lamda=2.331*pow(10,-20)*(Tavg)/(pressure*pow(delta,2)); keff = k_air/((dia_absorber/2)*log(dia_glass/dia_absorber)+b*lamda*((dia_absorber/dia_glass)+1)); return keff; } Error on compilation: The UDF library you are trying to load is not compiled for parallel use on the current platform (win64). I also tried to work on series fluent, but giving the error: The UDF library you are trying to load is not compiled for 3ddp on the current platform (win64) |
September 25, 2019, 22:45 |
#15 |
Alexander
Rep Power: 34 |
fluent GUI -> user-defined -> functions -> compiled -> BUILD
#include "udf.h" real tavg_glass; real tavg_abr; /*averge glasscover innerwall temperature*/ DEFINE_EXECUTE_AT_END(averagetempglasscoverinnerwall) { Domain *d; face_t f; real A[ND_ND]; real area_g = 0.0; real area_tot_g = 0.0; int ID = 8; /*this is the ID of the boundary wall that I want to get the temperature from*/ Thread *t; d = Get_Domain(1); t = Lookup_Thread(d,ID); tavg_glass = 0.0; begin_f_loop(f,t) { F_AREA(A,f,t); area_g = NV_MAG(A); area_tot_g += area_g; tavg_glass += F_T(f,t)*area_g; } end_f_loop(f,t) tavg_glass /= area_tot_g; Message("average glass cover temp = %g area_tot_g = %g\n",tavg_glass,area_tot_g); } /*averge absorber outerwall temperature*/ DEFINE_EXECUTE_AT_END(averagetempabsorberouterwall) { Domain *d; face_t f; real A[ND_ND]; real area_a = 0.0; real area_tot_a = 0.0; int ID = 9; /*this is the ID of the boundary wall that I want to get the temperature from*/ Thread *t; d = Get_Domain(1); t = Lookup_Thread(d,ID); tavg_abr = 0.0; begin_f_loop(f,t) { F_AREA(A,f,t); area_a = NV_MAG(A); area_tot_a += area_a; tavg_abr += F_T(f,t)*area_a; } end_f_loop(f,t) tavg_abr /= area_tot_a; Message("Tavgabrouterwall = %g area_tot_a = %g\n",tavg_abr,area_tot_a); } /*calculation of the property on the basis of the temperature*/ DEFINE_PROPERTY(thermalconductivity,c,t) { real keff; real lamda; real pressure= 0.0001; /*annulus gas pressure (mmhg=torr=10^-4)*/ real delta = 3.53*pow(10,-8); /*molecular diameter of annulus gas (cm)*/ real Tavg; /* degree calcius*/ real b=1.571; /* interactio coefficient*/ real gamma=1.4; /* ratio of specific heats for the annulus gas*/ real a; /* accomodation coefficient*/ real dia_absorber=0.07; /* absorber tube diameter*/ real dia_glass=0.109; /* glass cover inner diameter*/ real k_air=0.02551; /*normal conductivity*/ Tavg=(tavg_abr+tavg_glass)/2; lamda=2.331*pow(10,-20)*(Tavg)/(pressure*pow(delta,2)); keff = k_air/((dia_absorber/2)*log(dia_glass/dia_absorber)+b*lamda*((dia_absorber/dia_glass)+1)); return keff; } |
October 18, 2019, 04:19 |
#16 |
Sandeep
Hey all, I need some help on writing UDF for A Wall. The inlet temp changes in distance from 623K to 313K from upside down.
Problem: Zone 1. 0 cm to 5 cm is at 313K temp Zone 2. 5 cm to 10 cm is at 423K temp Zone 3. 10 cm to 15 cm is at 494K temp Zone 4. 15 cm to 30 cm Temp falls linearly to 613 K Zone 5. 35 cm to 31 cm is at 623K temp Hope anyone can help there is 5 zone. |
October 22, 2019, 05:07 |
#17 | |
Alexander
Rep Power: 34 |
look for DEFINE_PROFILE macro and F_CENTROID macro
best regards ****************************** press LIKE if this message was helpful |
November 2, 2022, 07:00 |
Question regarding Segmentation Fault
#18 | |
Rep Power: 4 |
I've been trying calculate average temeratures on a profile as well and get the same Segmentation Fault error when running the simulation. (I've run the same UDF that generated multiple temperatures in parallel mode and one correct temperature in serial mode for the original writer of this thread, with my id and domain of course.) Have you solved this issue and give me some advice? So the UDF is interpreted succesfully and I hooked it accordingly and I can initialize it. (Running in serial mode) Also I get the Segmentation Fault everytime I try to access flow or geometry values in my UDFs. If I use UDFs with constants and normal variables only, for example to define a not changing profile,, I'm able to run the simulation normally and the profile is set as expected. Does anyone know how to debug this? Thanks in advance! |
November 2, 2022, 23:49 |
#19 |
Alexander
Rep Power: 34 |
show the code you are using, better to open new thread on forum, however you may put it here as well
November 3, 2022, 04:11 |
#20 |
Rep Power: 4 |
define property, get wall temperature, udf |
