Simple UDF for piston movement
Like Tree1Likes
  • 1 Post By nader1977
Old   August 9, 2016, 13:05
Talking Simple UDF for piston movement
NicolasCheshire's Avatar
Nicolas Ramirez
NicolasCheshire is on a distinguished road
Dear all,
I'm working on an UDF with DEFINE_GRID_MOTION to move a boundary of a piston. This is the UDF:
#include "udf.h"
#include "unsteady.h"
#include "dynamesh_tools.h"
FILE *fp;
DEFINE_GRID_MOTION(obliqueWall,domain,dt,time,dtime)
    /*Declare Fluent parameters: face threat, nodes*/
    Thread *tf= DT_THREAD(dt);
    face_t f;
    Node *v;
    /*Declare Area vector A and d_displacement vector dx*/
    real NV_VEC(A);
    real NV_VEC(dx);
    /*Declare containers for variables*/
    real amplitude;
    real x;
    real w;
    real waveform;
    /*Declare containers for constants*/
    int n;
    float f1;
    float f2;
    float npx[176];
    float npy[176];
    int v1;
    int i;
    /*read node coordinates from the file */
    fp = fopen("meshPointsPP.out", "r");
        if (!fp)
            printf ("Error while opening file %s\n", "meshPointsPP.out");
            return 0;
        while (fscanf (fp, "%d %f %f\n",&v1, &f1, &f2) == 3 )
            npx[v1]=f1;
            npy[v1]=f2;
            printf("begin assignation of values of node %d\n",v1);
    fclose(fp);
    printf("finish: assignation of values\n");
    /* calculate displacement vector at the node normal to the surface */
    i=1;
    begin_f_loop(f,tf)
        printf("begin loop in faces\n");
        /* previous_time=PREVIOUS_TIME;*/
        F_AREA(A,f,tf);
        x=time;
        w=2*M_PI;
        amplitude=5e-6;
        waveform = amplitude*sin(w*x);
        printf("time = %f, disp = %f\n", time, waveform);
        dx[0]=A[0]*0;/*/NV_MAG(A)*waveform;*/
        dx[1]=A[1]/NV_MAG(A)*waveform;/*A[1]/NV_MAG(A)*sign;*/
        f_node_loop(f,tf,n)
            printf("begin: loop in nodes\n");
            v = F_NODE(f,tf,n);
            /* update node if the current node has not been previously */
            /* visited when looping through previous faces */
            if ( NODE_POS_NEED_UPDATE (v))
            /* indicate that node position has been update */
            /*so that it's not updated more than once */
            NODE_POS_UPDATED(v);
            NODE_COORD(v)[0]=dx[0]+npx[i];
            NODE_COORD(v)[1]=dx[1]+npy[i];
            i++;
    end_f_loop(f,tf);
The UDF loads the initial positions x and Y of the nodes from a text file with the following format,
1, 0.000000000E+00, 0.000000000E+00
2, 2.000000000E-04, 0.000000000E+00
3, 4.000000000E-04, 0.000000000E+00
4, 6.000000000E-04, 0.000000000E+00
I compile the UDF and assign it to the movingWall zone in dynamic mesh zone. Also enabling "Deform adjacent boundary layer with zone" and using only layering. I set up the transient case with a time step size of 0.001 [s] and 100 steps, [BUT] the mesh deforms oddly and I have negative volume cells in the first time step. My mesh is (initially) a square of 35 by 20 mm.
I welcome any suggestions to my UDF or set up. I think it is a scaling issue, but I don't know where to start.
Cheers!
NicolasCheshire is offline   Reply With Quote
Old   October 7, 2016, 11:36
Default dynamesh/in-cyn/crank-rpm PROBLEME
Gabes
nader1977 is on a distinguished road
# include "udf.h"
# define RPM RP_Get_Real("dynamesh/in-cyn/crank-rpm")
/********************************* User input starts *****************************************/
/* Cell zone ID list for pressure output (cell zone ID for combustion chamber). -1 is a flag
so please keep it. */
static int Zone_ID[]={2, -1};
/* Face zone ID list for work output (face zone ID for the piston) */
static int Piston_ID[]={6, -1};
/********************************** User input ends ******************************************/
static real work=0, start_CA=0, end_CA=0;
static int counter=0;
/* Function to calculate cell volume. It takes care of 2d and 2d axisymmetric case as well. */
static real C_MYVOLUME(cell_t c, Thread *tc)
real factor=1.0;
#if RP_2D
if (rp_axi) factor=2*M_PI;
#endif
return C_VOLUME(c,tc)*factor;
/* Function to calculate face area. It takes care of 2d and 2d axisymmetric case as well. */
static void F_MYAREA(real * x, face_t f, Thread *tf)
real factor=1.0;
F_AREA(x, f, tf);
#if RP_2D
#endif
NV_S(x, *=, factor);
DEFINE_ON_DEMAND(Indicated_work)
if(counter==0)
Message0("\n\n********************** IC Indicated Work Results *****************************\n");
Message0("\nIndicated work calculation has not started. Please do at least one time step.\n");
Message0("\nStart CA :%5.2f (deg) End CA :%5.2f (deg) Work : %9.3e (J)", start_CA, end_CA, work);
Message0("\n\n************************************ ******************************************\n");
else
Message0("\nIndicated work calculation started at :%7.2f (deg)", start_CA);
Message0("\nIndicated work calculation finished at :%7.2f (deg)", end_CA);
Message0("\nFor the above duration, the indicated work is :%12.4e (J)", work);
DEFINE_ON_DEMAND(reset)
counter=0;
work=0;
start_CA=0;
end_CA=0;
Message0("\n\n******************************** WARNING *************************************\n");
Message0("\nNote that this resets indicated work and the calculation start CA to zero.");
Message0("\nPlease save the data file to save the new values.");
DEFINE_EXECUTE_AT_END(output_results)
#if !RP_HOST
int i;
real pressure, volume, fmf, mass, work_one_dt, x[ND_ND];
Thread *tc, *tf;
cell_t c;
face_t f;
FILE *fp_results;
Domain* domain;
domain=Get_Domain(1);
#if PARALLEL
if(I_AM_NODE_ZERO_P)
#endif
if(!(fp_results=fopen("work.txt","a")))
Message0("\nCan not open file-aborting!!");
exit(0);
if(counter==0)
start_CA = (CURRENT_TIME-CURRENT_TIMESTEP)*RPM*6.0+RP_Get_Real("dynamesh/in-cyn/crank-start-angle");
#if PARALLEL
#endif
fprintf(fp_results, " CA Volume Pressure Yfb Work\n");
counter ++;
end_CA=CURRENT_TIME*RPM*6.0+RP_Get_Real("dynamesh/in-cyn/crank-start-angle");
#endif
node_to_host_int_1(counter);
node_to_host_real_2(start_CA, end_CA);
#if !RP_HOST
/* Calculate volume weighted pressure and burnt fuel mass fraction */
pressure=0;
volume=0;
fmf=0;
mass=0;
i=0;
while(Zone_ID[i]>=0)
tc=Lookup_Thread(domain, Zone_ID[i]);
begin_c_loop_int(c, tc)
pressure += C_P(c,tc) * C_MYVOLUME(c,tc);
volume += C_MYVOLUME(c,tc);
if(sg_premixed)
fmf += C_PREMIXC(c,tc) * C_R(c,tc) * C_MYVOLUME(c,tc);
mass += C_R(c,tc) * C_MYVOLUME(c,tc);
end_c_loop_int(c, tc)
i++;
pressure = PRF_GRSUM1(pressure);
volume = PRF_GRSUM1(volume);
fmf = PRF_GRSUM1(fmf);
mass = PRF_GRSUM1(mass);
pressure /= volume;
fmf /= mass;
/* Calcualte work by piston. Only pressure force is accounted for and viscous force is neglected. */
work_one_dt=0;
i=0;
while(Piston_ID[i]>=0)
tf=Lookup_Thread(domain, Piston_ID[i]);
begin_f_loop(f, tf)
F_MYAREA(x, f, tf);
work_one_dt += CURRENT_TIMESTEP * F_P(f,tf) * NVD_DOT(x, WALL_F_GRID_VV(f, tf)[0], WALL_F_GRID_VV(f, tf)[1], WALL_F_GRID_VV(f, tf)[2]);
end_f_loop(f, tf)
i++;
work_one_dt = PRF_GRSUM1(work_one_dt);
work += work_one_dt;
#endif
node_to_host_real_1(work);
#if !RP_HOST
/* Output volume, pressure, burnt fuel mass fraction */
#if PARALLEL
#endif
fprintf(fp_results, "%8.2f %12.4e %12.4e %12.4e %12.4e\n", end_CA, volume, pressure, fmf, work);
fclose(fp_results);
#endif
DEFINE_RW_FILE(write_data, fp)
Message0("\nWriting user defined data to the data file...\n");
#if PARALLEL
#if RP_HOST
fprintf(fp, "\n%d", counter);
fprintf(fp, "\n%e", work);
fprintf(fp, "\n%e", start_CA);
fprintf(fp, "\n%e", end_CA);
#endif
#else
#endif
DEFINE_RW_FILE(read_data, fp)
Message0("\nReading user defined data from the data file...\n");
#if PARALLEL
#if RP_HOST
fscanf(fp, "%d", &counter);
fscanf(fp, "%e", &work);
fscanf(fp, "%e", &start_CA);
fscanf(fp, "%e", &end_CA);
#endif
#else
#endif
host_to_node_int_1(counter);
host_to_node_real_3(work,start_CA,end_CA);
ERROR IS
..\..\src\work.c(195) : error C2109: subscript requires array or pointer type
Randal0 likes this.
nader1977 is offline   Reply With Quote
dynamic mesh zones, grid motion, udf crash
Issues with UDF for ball movement inside a valve A.Jalal Fluent UDF and Scheme Programming 1 July 30, 2015 02:11
UDF for 2D translational movement ThinkQuick Fluent UDF and Scheme Programming 0 July 24, 2012 02:59
Simple UDF array question [Fluent] Patrick1 Fluent UDF and Scheme Programming 0 April 19, 2012 02:41
Pb with simple Fluent UDF example for inlet francois FLUENT 0 October 9, 2008 11:34
simple rigid body motion UDF Dan FLUENT 0 January 11, 2006 06:48
