Transient Velocity Inlet (2d synthetic jet) UDF
Like Tree2Likes
  • 1 Post By akulagr
  • 1 Post By OpenFOAM-2016
Old   July 30, 2016, 10:32
Default Transient Velocity Inlet (2d synthetic jet) UDF
akulagr is on a distinguished road
Hello all
my case is consisted of a flow over a hump with a synthetic jet in the interior of the hump. essentially the jet is required to blow and suck air with a frequency of 138.5 Hz at an approximate velocity out of the slot of the jet of 26.6 m/s
prescribed as : u=o
v= speed*cos(2*pi*f)
I'm fairly new in setting up User defined functions for boundary conditions, from digging around this forum and the literature the UDF for this particular case seems to be simple enough to formulate, but im getting some divergence after certain number of iterations. i wanted to double check whether im implementing the UDF correctly for the desired purpose.
im using a pressure outlet boundary condition to hook the UDF
/* unsteady.c */
/* UDF for specifying a transient velocity profile boundary condition */
#include "udf.h"
DEFINE_PROFILE(SJ_velocity, thread, position)
face_t f;
begin_f_loop(f, thread)
real freq=138.5;
real t = RP_Get_Real("flow-time");
F_PROFILE(f, thread, position) = 26.6*cos(freq*(t)*(2.*3.141592654));
end_f_loop(f, thread)
I was wondering if someone could point me in the right direction on implementing this function for this particular case
much appreciated
David
OpenFOAM-2016 likes this.
akulagr is offline   Reply With Quote
Old   July 31, 2016, 09:38
please guys any help will be greatly appreciated
Old   August 13, 2016, 12:12
Mike
OpenFOAM-2016 is on a distinguished road
OK. I guess here's the problem. From 0 to pi/2 the velocity is positive so there is no problem and the problem is being solved. but after this point you got negative velocity at the inlet so that's where the divergence occurs because the flow is getting out the domain and the outlet boundary condition cannot stand this condition. OK try this: set an average velocity at a value that is larger than the amplitude of the oscillation. So the velocity of the inlet port will never get negative. Then see how's the results.
zayryn likes this.
OpenFOAM-2016 is offline   Reply With Quote
Old   July 30, 2018, 04:04
Default 3D synthetic jet
Arun jacob
Arun Jacob is on a distinguished road
I am working on synthetic jet flow simulation. i want to know that how can i generate a 3d UDF for the following parameters velocity = 195m/sec, Frequency is 17.
I am also attaching the udf generated in 2d. Now i want to do the same in 3D..what are the changes that i should made to get the result.
#include"udf.h"
DEFINE_PROFILE(SJ_velocity,thread,position)
face_t f;
begin_f_loop(f,thread)
real freq=17;
real t= RP_Get_Real("flow-time");
F_PROFILE(f,thread,position) =195*sin(freq*(t)*(2.*3.141592654));
end_f_loop(f,thread)
Arun Jacob is offline   Reply With Quote
Old   October 18, 2018, 02:31
Default 3d synthetic jet
Vilas
tadevilas is on a distinguished road
Sir.
I have also same problem can you help me.
tadevilas is offline   Reply With Quote
transient 2d, udf, user defined b.c.
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 07:45
UDF: Change boundary condition. Velocity inlet to pressure inlet at time "t" jpina FLUENT 10 April 11, 2015 15:19
problem of the drag's convergence for a circular cylinder with a synthetic jet (udf) bia FLUENT 0 February 17, 2015 12:06
How to set transient velocity inlet bc LijieNPIC OpenFOAM 1 September 4, 2011 12:43
Fluent6.0 UDF inlet velocity BC David FLUENT 5 September 7, 2002 03:07
