UDF for particle injection using file
Like Tree1Likes
  • 1 Post By shahjehan
Old   July 20, 2016, 22:49
Lightbulb UDF for particle injection using file
shahjehan's Avatar
Syed Shah Jehan Gillani
shahjehan is on a distinguished road
Hi All!!
It is usually required to initialize static bed domain with particles in fluidized bed multiphase simulations. Mostly users ask about particle initialization of particles but there is no proper answer to their question.
I was wondering how a udf could be written for file injection.
Here I tried to sort out this problem and coded a udf using the logic given in initialization example provided in ansys udf guide. where this logic was utilized to initialize temprature field in the domain.
Can any one here please debug udf if any and improve the udf.?
initialization.c
Before this I found a way to write injection file by the suggestion of Mr. Daniele [ghost82].
In macroscopic particle model addon module in ansys fluent 17 there is a provision to create volume injection (cylinder/box).
These steps were followed:
In ansys 17.0 activate macroscopic particle model.
After turning on Macroscopic model (MPM)
created an injection and set for volume injection.
now initialize in MPM panel.
Fluent prompt will show # particles created.
Now, display injection in the MPM panel.
this will copy injection particle data to Discrete model injection.
Go to Graphics-->particle track panel
Here select option reporting--> current position in left bottom of the panel
and write to file. Now you have a filename.his file in your working directory.
Import that filename.his into excel and follow the instruction given by the post
http://www.cfd-online.com/Forums/flu...tml#post556836
This is a long way but really works in 3D fluent cases surely.
initialization.c
Tarekpower1 likes this.
shahjehan is offline   Reply With Quote
Old   March 27, 2020, 06:03
hamxing is on a distinguished road
Hi Shahjehan,
I've found your post when i'm searching a way to initiate a static bed domain in fluidized bed. I've tried your suggestion to enable Macroscopic model (MPM) but it is only available in 3D model.
Is there any other methods than the MPM ?
Regards,
Ham Xing
hamxing is offline   Reply With Quote
Old   June 28, 2020, 11:44
Elo Nielsen
EloNielsen is on a distinguished road
Dear Shahjehan
I can see your question is from March. Did you get an answer?
EloNielsen is offline   Reply With Quote
dpm, injection_file
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
