Can I put porosity/permeability into each cells by UDF?
Like Tree2Likes
  • 1 Post By Bruno Machado
Old   June 28, 2016, 06:41
Default Can I put porosity/permeability into each cells by UDF?
S.J Chung
ssavi22 is on a distinguished road
Hi guys
Can I put porosity/permeability into each cells by UDF??
I found inlet velocity problem, but cannot find input to each cells...
Thank you for your help
ssavi22 is offline   Reply With Quote
Old   June 28, 2016, 07:26
Bruno Machado
Bruno Machado is on a distinguished road
Originally Posted by ssavi22 View Post
Hi guys
yes. use the DEFINE_PROFILE macro.
ssavi22 likes this.
Bruno Machado is offline   Reply With Quote
Old   June 28, 2016, 08:48
S.J Chung
Can I get some examples?
Old   June 28, 2016, 08:53
Bruno Machado
DEFINE_PROFILE(porosity,t,i)
cell_t c;
begin_c_loop(c,t)
C_PROFILE(c,t,i) = 0.5;
end_c_loop(c,t)
ssavi22 likes this.
each cells, permeability, porosity
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
How to access only one phase in multiphase model by UDF wersoe Fluent UDF and Scheme Programming 1 January 4, 2017 08:11
[ICEM] Problem with prism cells sidharath ANSYS Meshing & Geometry 0 September 1, 2015 08:09
[snappyHexMesh] snappyHexMesh Segmentation Fault avd28 OpenFOAM Meshing & Mesh Conversion 11 May 11, 2015 21:32
snappyHexMesh in parallel - FOAM Fatal IO Error mturcios777 OpenFOAM Running, Solving & CFD 4 August 10, 2012 20:18
