Effects of vortex induced vibrations on cylinders
Like Tree1Likes
  • 1 Post By obscureed
Old   May 18, 2016, 07:16
Default Effects of vortex induced vibrations on cylinders
Daban M. salih
Daban is on a distinguished road
HELLO WORLD
i am doing a simulation on effect of vortex induced vibration on cylinders, i wrote a udf file like this:
#include "udf.h"
DEFINE_SDOF_PROPERTIES(sdof_props, prop, dt, time, dtime)
real cgy;
real k = 170;
cgy = DT_CG(dt)[1];
prop[SDOF_MASS] = 170;
prop[SDOF_ZERO_TRANS_Y] = TRUE;
prop[SDOF_IXX] = 122.4;
prop[SDOF_IYY] = 122.4;
prop[SDOF_IZZ] = 40.8;
prop[SDOF_LOAD_F_Y] = -k*cgy;
printf("\n updated 6DOF properties");
what i expect is a movement (vibration) in y direction but when i do the analysis my cylinder moves in x direction. can anyone tell me if i wrote the correct udf file !!? von karman effect.PNG
Daban is offline   Reply With Quote
Old   May 18, 2016, 08:24
pakk will become famous soon enough
You say you expect a movement in y-direction. But you type:
This tells Fluent that there should be zero translation in y-direction...
Maybe you want it to be frozen in x-direction?
prop[SDOF_ZERO_TRANS_X] = TRUE;
pakk is offline   Reply With Quote
Old   May 18, 2016, 11:11
Daban M. salih
thank you sir for ur reply, i am new to ansys fluent, so if i want a spring based oscillation in y direction, how should i write a udf for it?
Old   May 18, 2016, 11:17
Euh... Didn't I already answer that in my first reply???
Old   May 19, 2016, 03:44
Rahil
rahilvalani is on a distinguished road
Hi there,
I am also trying to simulate Vortex induced vibrations of a cylinder. My question is that once you hook this udf to the cylinder, does ansys automatically calculated the velocity of the cylinder or do you have to write another udf for this?
Also I tried using this by using dynamic mesh in fluent but its giving me weird Coefficient of lift of about 100-200 and also the cylinder just moves in one direction and goes off the domain. Can someone please help?
rahilvalani is offline   Reply With Quote
Old   January 5, 2018, 12:25
Default Vortex Induced Vibrations of Circular Cylinder
Sajid
Sajid Sarfraz is on a distinguished road
Hello
I am Sajid
I am doing vortex induced vibrations in ANSYS Fluent using following UDF.
#include "udf.h"
real cg;
real k = 1*1.26*1.26;
cg = DT_CG(dt)[8];
prop[SDOF_MASS] = 1;
prop[SDOF_ZERO_ROT_X] = TRUE;
prop[SDOF_ZERO_ROT_Y] = TRUE;
prop[SDOF_LOAD_F_Y] = -k*cg;
However i am not getting movement of cylinder in Y dirn. Can anybody guide me
Thx
Sajid Sarfraz is offline   Reply With Quote
Old   January 11, 2018, 10:47
obscureed is on a distinguished road
Hi Sajid,
"DT_CG(dt)" is the position vector of the centre of gravity of the dynamic thread. So it does not make sense to use "DT_CG(dt)[8]" -- if you want the y-coordinate, then it is "DT_CG(dt)[1]". What was the basis for choosing 8?
The rest of the UDF looks OK (presuming this is a 2D simulation). It might help to send a message to screen before the end of the function, just to check that the UDF is hooked in correctly and to see if anything is strange:
Message("Exiting SDOF UDF with y = %g, force = %g\n",cg,-k*cg);
Sajid Sarfraz likes this.
obscureed is offline   Reply With Quote
Old   March 12, 2018, 10:59
Default Regarding VIV simulation in amsys fluent
Niraj Sonule
nirajnisa is on a distinguished road
I am trying to do VIV simulation of cylinder but new to ansys..can you provide me proper procedure to carry out my work
nirajnisa is offline   Reply With Quote
Vortex induced Vibrations aravindh28.4 OpenFOAM 36 November 23, 2017 14:43
Vortex Induced Vibrations smm6889 ANSYS 2 February 18, 2014 11:00
pimpleDymFoam and Vortex Induced Vibrations on a 3D cylinder MrAnderson OpenFOAM Running, Solving & CFD 1 February 17, 2014 19:26
FSI including flow induced vibrations in porous models oj.bulmer FLUENT 6 October 15, 2013 13:16
Presenation of vortex strength and velocity concept? fruitkiwi Main CFD Forum 0 September 26, 2012 23:08
