UDF code is not compatible with 64 bits
Like Tree1Likes
  • 1 Post By `e`
Old   March 30, 2016, 10:55
Default UDF code is not compatible with 64 bits
mimi
cik mimi is on a distinguished road
Hi guys, now I am understand that by using the compiled codes, my
udf error: structured references is not implemented...........
can be resolved.
However, my current error message is showing that the codes is not compatible with the 64 bits windows 7 system.
What should I do? Appreciate if friends can answer my question.
cik mimi is offline   Reply With Quote
Old   March 30, 2016, 19:19
`e`
`e` is on a distinguished road
Ensure you are compiling and loading the UDF correctly by reading my compiling process for Fluent UDFs with an existing library loaded.
cik mimi likes this.
`e` is offline   Reply With Quote
Brownian Motion UDF Code Confuser FLUENT 3 August 13, 2021 02:14
how to use UDF to obtain the thred of the interface between the liquid and the wall? hellowqy Fluent UDF and Scheme Programming 8 December 17, 2015 11:03
something wrong when compiling udf, however the code is correct when interpreting richard ben Fluent UDF and Scheme Programming 7 May 11, 2013 08:36
UDF code Wu chin Fluent UDF and Scheme Programming 0 July 15, 2012 12:44
Optimizing UDF Code Cebeci FLUENT 18 September 6, 2003 04:40
