Condensation-VOF
Like Tree2Likes
  • 2 Post By MDSHUJAN
Old   March 11, 2016, 05:30
Default Condensation-VOF
Rajukiran Antham
RAJ KIRAN is on a distinguished road
I am working on my Master thesis. My goal is to simulate condensation in a horizontal pipe (Stratified flow) using fluent. I am using VOF method. I am using a different condensation model so I need to write a UDF for mass transfer. From what I have understood after reading manual, I can use either DEFINE_MASS_TRANSFER or DEFINE_SOURCE Macros.
--If i use MASS_TRANSFER macro, How will fluent interpret this macro? Will it automatically calculate the source terms for volume fraction equation and energy equation? If it does, How will it calculate?
--If i use DEFINE_SOURCE macro, Should I add source terms for both liquid and steam phases? Is this compulsory because volume fraction equation is solved only for secondoray phase.
Thanks in advance
RAJ KIRAN is offline   Reply With Quote
Old   June 17, 2016, 10:40
SHUJAN
MDSHUJAN is on a distinguished road
Thanks in advance
You need to add source for both phase. There is a Tutorial from ANSYS FLUENT named horizontal film evaporation. Try to read it. Adding only 1 source will increase or decrease total mass of the system.
RAJ KIRAN and SACHIN1639 like this.
MDSHUJAN is offline   Reply With Quote
Old   June 17, 2016, 10:58
Rajukiran Antham
Thanks for the reply,
I figured it out
Regards,
Rajukiran
Old   June 17, 2016, 11:18
SHUJAN
I figured it out
Regards,
Rajukiran
Hi Kiran. Did you get condensation from your simulation? I am trying to simulate Loop Heat Pipe, I got evaporation, but no condensation.
If you got condensation, I will want to look at your udf, or what model you use? I am using Lee model.
Old   June 18, 2016, 12:05
Rajukiran Antham
yes,
I am not using Lee model. I used condensation model which is based on surface renewal theory.
Old   July 24, 2016, 11:26
SACHIN SHNDE
SACHIN1639 is on a distinguished road
raj kiran sir can you please send me your ufd code?i am trying to wright the code from last30 days please help me?
sachin1639@gmail.com
SACHIN1639 is offline   Reply With Quote
Old   July 24, 2016, 12:47
Rajukiran Antham
Sorry, I can't send it to you, because I did it for a company as part of my thesis, However you can ask me questions and I can help you as much as I can.
Evaporation and condensation model in VOF ic3lemon Fluent Multiphase 0 December 12, 2015 07:56
VOF with evaporation and condensation UDF's gerardosrez Fluent Multiphase 4 March 15, 2015 16:01
Condensation UDF in VOF foolstop Fluent UDF and Scheme Programming 6 June 23, 2013 22:59
VOF - NO Condensation !!!!. JSM FLUENT 2 May 12, 2012 10:08
Using UDF in VOF model for Condensation Crystal FLUENT 6 September 26, 2004 19:08
