Compiling Problem with DEFINE_PROFILE
Like Tree1Likes
  • 1 Post By pakk
Old   March 4, 2016, 08:20
Default Compiling Problem with DEFINE_PROFILE
noxtul
D-Nox is on a distinguished road
Hello People,
I wanna build some custom boundary velocity profile for my Fluent case running in parallel with 2 nodes.
I wrote this c source code:
#include "udf.h"
#include "math.h"
#include "stdio.h"
#define z0 1e-2 //unit m
#define zref 6 //unit m
#define k 0.4 //cte Von Karman
#define vref 35.7632 //unit m/s
DEFINE_PROFILE(xvinlet,t,i)
    float X[ND_ND];
    float u,h,Vwind,Vtrain;
    int alfa;
    face_t f;
    FILE *fp;
    fp=fopen("inputs.txt","r");
    fscanf(fp,"%i %f",&alfa,&Vtrain);
    fclose(fp);
    u=(k*vref)/(log((zref+z0)/z0));
#if !RP_HOST /* serial or node */
    begin_f_loop(f,t)
        F_CENTROID(X,f,t);
        h=X[1];
        Vwind=(u/k)*log((h+z0)/z0);
        F_PROFILE(f,t,i)=-Vwind*cos(alfa)-Vtrain;
    end_f_loop(f,t);
#endif
When i tried to compile it, Fluent brought me this log:
Copied Z:\/x_velocity_inlet.c to libudf\src
Creating user_nt.udf file for 3ddp_host ...
(system "copy "c:\PROGRA~1\ANSYSI~1\v150\fluent"\fluent15.0.7\sr c\makefile_nt.udf "libudf\win64\3ddp_host\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\3ddp_host")# Generating ud_io1.h
x_velocity_inlet.c
# Generating udf_names.c because of makefile x_velocity_inlet.obj
udf_names.c
udf_names.c(8) : warning C4113: 'void (*)()' differs in parameter list from 'void (*)(void)'
# Linking libudf.dll because of makefile user_nt.udf udf_names.obj x_velocity_inlet.obj
Microsoft (R) Incremental Linker Version 11.00.61030.0
Copyright (C) Microsoft Corporation. All rights reserved.
Creating library libudf.lib and object libudf.exp
Creating user_nt.udf file for 3ddp_node ...
(system "copy "c:\PROGRA~1\ANSYSI~1\v150\fluent"\fluent15.0.7\sr c\makefile_nt.udf "libudf\win64\3ddp_node\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\3ddp_node")# Generating ud_io1.h
x_velocity_inlet.c
udf_names.c
Done.
As everybody can see, the compiler make a new source file called udf_names.c that have a fail in 8th lane (C4113). I dont know how to solve it. Please help me.
My system is:
  • win7x64 profesional
  • Fluent 15.07
  • MSVC 2012 Express
  • .Net Framework 4.5
  • Microsoft SDK 7.1
I opened Fluent with the SDK command prompt, so enviromment variables should be fine.
The udf_names.c source code that automatically created the compiler is:
/* This file generated automatically. */
/* Do not modify. */
#include "udf.h"
#include "prop.h"
#include "dpm.h"
extern DEFINE_PROFILE(xvinlet,t,i);
__declspec(dllexport) UDF_Data udf_data[] = {
{"xvinlet", (void (*)())xvinlet, UDF_TYPE_PROFILE},
__declspec(dllexport) int n_udf_data = sizeof(udf_data)/sizeof(UDF_Data);
#include "version.h"
__declspec(dllexport) void UDF_Inquire_Release(int *major, int *minor, int *revision)
*major = RampantReleaseMajor;
*minor = RampantReleaseMinor;
*revision = RampantReleaseRevision;
<edited> I solved LNK200 and LNK1120 moving the #if RP_HOST condition inside the DEFINE_PROFILE macro as we can see now, but the c4113 error still persist. The libudf.dll can be loaded but i dont know if its will work fine.
D-Nox is offline   Reply With Quote
Old   March 4, 2016, 10:45
pakk will become famous soon enough
In my experience, that error C4113 can be safely ignored, it is a mistake by the Fluent programmers that does not have any real consequences.
I would be more concerned with the two other errors that are shown: LNK2001 and LNK1120. Those are new for me.
D-Nox likes this.
pakk is offline   Reply With Quote
C_T(c,t) problem while compiling (OK interpreted) crevoise Fluent UDF and Scheme Programming 6 February 4, 2014 08:16
Problem with compiling new solver palazi88 OpenFOAM Programming & Development 2 December 24, 2013 20:52
problem with compiling the source code michel1988 OpenFOAM Installation 1 April 17, 2013 18:19
COMPILING PROBLEM ammi FLUENT 1 December 7, 2006 05:07
problem in compiling UDF ammi reddy FLUENT 1 December 1, 2006 07:45
