UDF compiler-ANSYS Fluent release 16.2
Like Tree1Likes
  • 1 Post By `e`
Old   January 7, 2016, 08:18
Default UDF compiler-ANSYS Fluent release 16.2
Giorgio
gigivmasche is on a distinguished road
Hey buddies,
quick question (hoping someone already fell into my issue):
I am working with the last release of Fluent, 16.2.
my environment is windows 7 (x64).
which compiler do I have to use? which Visual Studio i mean. Do i need even a SDK tool?
i have tried with Visual C++ 2008 Express Edition and .NET Framework 2.0 Software Development Kit (SKD) for 64bit but nothing: I think it built the library but when I click on Load, I am facing Error Object F#, which I don't know what it means.
I've tried with Visual Studio C++ 2010, 2013 FOLLOWING many istructions I found in CFD-online shared by people who got my same problem.
I am now at the conclusion that perhaps my release needs different approach!!
I am new to UDF. I hope I've been clear!
PLEASE ANYONE COULD HELP ME?
G
gigivmasche is offline   Reply With Quote
Old   January 7, 2016, 16:06
`e`
`e` is on a distinguished road
Microsoft Visual Studio Express 2013 for Desktop works with ANSYS Fluent 16.2. Older versions of Visual Studio should also work (backwards compatibility).
gigivmasche likes this.
`e` is offline   Reply With Quote
Old   January 8, 2016, 16:33
Giorgio
That works! Many thanks.
Old   March 27, 2016, 06:55
ris
ris123 is on a distinguished road
Hi I'm using window sdk for window 8 and visual studio 2012 for fluent ansys. In order to open fluent , i will need to input some command in the window sdk to get window 64 bits release version. Do you know of the code?
ris123 is offline   Reply With Quote
Old   March 27, 2016, 07:06
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
No need to use SDK with newer fluent
Far is offline   Reply With Quote
Old   March 27, 2016, 08:16
ris
But when i want to compile the file it will show ' The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).
The system cannot find the file specified.' this error message. What should I do ??? Im using fluent 15.0
Old   March 27, 2016, 13:26
Far
Sijal
install visual studio 2012 professional
Old   March 27, 2016, 21:41
ris
Hi Far,
I think i would need some command code to be keyed in to the developer command prompt to open fluent right? Cannot just open directly ??
Old   March 28, 2016, 10:27
Far
Sijal
no. In newer version you dont need this
Old   April 7, 2016, 23:14
kashi
csuohio is on a distinguished road
try this it might help u if u still experiencing problem in opening let me knowfluent.jpg
csuohio is offline   Reply With Quote
UDF Defining in ANSYS FLUENT 16.2 in Win 10 Sadegh.A Fluent UDF and Scheme Programming 11 February 15, 2017 15:45
[B]the compiler keep on compile previous udf without updating new udf?[/B] fruitkiwi Fluent UDF and Scheme Programming 5 July 24, 2014 20:38
Fluent UDF for thermal NOx larsschwarzer Fluent UDF and Scheme Programming 1 July 18, 2014 09:39
Ansys FLUENT UDF - Velocity profile (of known values) across edge / surface emmkell FLUENT 0 October 20, 2011 08:37
FLUENT to ANSYS Temperature Mapping Procedure schreiberc1 FLUENT 0 June 29, 2006 14:50
