UDM just for fluid zone
Like Tree9Likes
  • 1 Post By nima_nz
  • 3 Post By `e`
  • 1 Post By nima_nz
  • 1 Post By `e`
  • 1 Post By `e`
  • 2 Post By `e`
Old   January 6, 2016, 12:05
Default UDM just for fluid zone
Nima
nima_nz is on a distinguished road
Hi
My domain includes both solid zone and fluid zone, but when I use
thread_loop_c(t,domain)
begin_c_loop(c,t)
The UDF loops over all cells. How can I set it just for the fluid zone?
Thanks
vavnoon likes this.
nima_nz is offline   Reply With Quote
Old   January 6, 2016, 14:45
Nima
i have tried to use the following macro FLUID_THREAD_P(t) but it is giving an error message, saying structure reference not implemented.
Old   January 6, 2016, 16:41
`e`
`e` is on a distinguished road
You can distinguish between cell zones using their threads. For example:
Thread *tfluid = Lookup_Thread(domain,FLUID_ID);
    if (t==tfluid)
        Message("This cell belongs to the fluid cell zone!");
where FLUID_ID is the integer value of the cell zone (found under cell zones in Fluent).
yakovlev-i-a, nima_nz and chek321 like this.
`e` is offline   Reply With Quote
Old   January 8, 2016, 16:43
Nima
    if (t==tfluid)
You mean I found the fluid thread at first and then import these thread to the main UDF?
zhixin likes this.
Old   January 8, 2016, 18:26
`e`
No, you only need one UDF. First, grab the cell zone ID via the GUI from Define > Cell Zone Conditions and selecting the corresponding cell zone. Second, use this integer in your UDF in place of FLUID_ID.
For good coding practice, you should define the cell zone ID at the beginning of the file (which replaces FLUID_ID with the integer, for example 10, everywhere in the code):
#define FLUID_ID 10
nima_nz likes this.
Old   January 10, 2016, 03:45
Nima
#define FLUID_ID 10
Dear `e`
The summary of the structure of my UDF is as follows:
#include "udf.h"
DEFINE_ON_DEMAND(myudftest)
Domain *d;
Thread *t;
cell_t c;
real parameters; /*defining parameters*/
real VEL; /* Relative air velocity (m/s)*/
d=Get_Domain(1);
thread_loop_c(t,d) {
begin_c_loop(c,t)
VEL=sqrt(pow(C_U(c,t),2.0)+pow(C_V(c,t),2.0)+pow(C _W(c,t),2.0));
C_UDMI(c,t,0)=...;
end_c_loop(c,t)
As you see, I need the velocity magnitude, but when I have solid domain because of lack of velocity in the solid domain, my UDF doesn't work.
If it's possible for you, would you please tell me what you mean?
You mean this?
#include "udf.h"
Domain *d;
Thread *t;
cell_t c;
Thread *tfluid=lookup_Thread(d,FLUID_ID for example 10)
thread_loop_c(t,d)
if (t==tfluid)
begin_c_loop(c,t)
C_UDMI(c,t,0)=...;
end_c_loop(c,t)
Thank you very much.
Old   January 10, 2016, 21:42
`e`
Yes, only operate the velocity evaluation on the fluid cell zone thread.
A few comments: initialise your VEL variable with zero such that the solid will default to zero (and avoid errors when accessing VEL for solid cells); declare tfluid with the other declarations; and include curly brackets for the code block within the if statement (for clarity and in case the compiler misinterprets what you want).
nima_nz likes this.
Old   January 11, 2016, 07:34
Nima
Dear `e`
Thank you for your help and time.
I used this structure:
#include "udf.h"
	Domain *d;
	Thread *tf;
	cell_t c;
	real parameter;
	int ID=5;
	d=Get_Domain(1);
	tf=Lookup_Thread(d,ID);
	thread_loop_c(tf,d)
			begin_c_loop(c,tf)
				VEL=sqrt(pow(C_U(c,tf),2.0)+pow(C_V(c,tf),2.0)+pow(C_W(c,tf),2.0));
				C_UDMI(c,tf,0)=name;
			end_c_loop(c,tf)
It's truly interpreted but after I write case and data in new name (as fluent say), and open that case, when I Execute on demand, by
define>user-defined>execute on demand
It doesn't work!
Is there any way to solve this problem?
Old   January 11, 2016, 09:15
pakk will become famous soon enough
It doesn't work!
What do you mean "It doesn't work!"? Be more precise!
Do you get warnings?
Do you get wrong results?
Do you get no results?
I am surprised if this code interpreted without warnings, because of the line
What is "name" doing there?
pakk is offline   Reply With Quote
Old   January 11, 2016, 09:28
Nima
I mean after I execute the UDM on demand, fluent give an error
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
'name' is an example here. It isn't in my UDF.
For example first I define a function like F then I wrote:
C_UDMI(c,tf,0)=F;
Old   January 11, 2016, 09:42
If you want us to find the problem in your UDF, you should show us the code of your UDF. Don't show us a version where you changed things and left out things.
Old   January 11, 2016, 10:30
Nima
Dear Pakk,
It's a simple UDF to calculating operative temperature in the domain.
#include "udf.h"
DEFINE_ON_DEMAND(Opertemp)
	Domain *d;
	Thread *t;
	cell_t c;
	real TA;		/* Air temperature (°C)*/
	real TR;		/* Mean radiant temperature (°C)*/
	real OT;		/*operative temperature*/
	d=Get_Domain(1);	/* Get the domain using ANSYS FLUENT utility */
	thread_loop_c(t,d)	/* Loop over all cell threads in the domain */
		begin_c_loop(c,t)	/* Loop over all cells */
			TA=C_T(c,t)-273.15;
			TR=26.563;		/*Mean radiant temperature*/
VEL=sqrt(pow(C_U(c,t),2.0)+pow(C_V(c,t),2.0)+pow(C_W(c,t),2.0));
			OT=(TR+(TA*sqrt(10*VEL)))/(1+sqrt(10*VEL));
			C_UDMI(c,t,0)=OT;
		end_c_loop(c,t)
As you see, I need velocity components in all cells, but because lack of velocity components in the solid domain when I execute the udf on the domain fluent give an error. I know it's because of velocity, because when I do this:
#include "udf.h"
	Domain *d;
	Thread *t;
	cell_t c;
			TA=C_T(c,t)-273.15;
VEL=0.15;
			C_UDMI(c,t,0)=OT;
		end_c_loop(c,t)
after executing on demand, there is no error.
Thanks.
Old   January 11, 2016, 19:15
`e`
The looping macro thread_loop_c(t,d) will always loop through all cell threads in a given domain (d). The cell thread pointer (t) is an output used within the code block; I suspect Fluent is ignoring your evaluation of "tf=Lookup_Thread(d,ID);" within this code block.
Have a careful read of my example above as your code was mostly correct before (using the conditional statement to check if the current thread in the loop was the fluid thread).
nima_nz and zhixin like this.
Old   January 12, 2016, 04:09
Nima
Dear `e`
Thank you very very much.
I wrote my code like this:
#include "udf.h"
	Domain *d;
	Thread *t;
	cell_t c;
	int ID=29;
	Thread *tf=Lookup_Thread(d,ID);
		if(t==tf)
				TA=C_T(c,t)-273.15;
				C_UDMI(c,t,0)=OT;
			end_c_loop(c,t)
		else
				OT=0;
				C_UDMI(c,t,0)=OT;
			end_c_loop(c,t)
Now, there isn't any error, but something is wrong. because the contoure of 'Memory 0' is zero!
I think it's because of wrong Fluid thread ID. I find the fluid threads from boundary condition. Would you please tell me how I can find the true ID?
Thanks.
Old   January 12, 2016, 18:29
`e`
If the UDM-0 is zero everywhere then you may have the wrong cell zone ID of the fluid thread.
Specifically: left click the fluid cell zone under "Zone" and read the integer underneath "ID" on the lower right of the panel. The "Type" should also be set to "fluid".
Old   January 13, 2016, 03:45
Nima
Thanks a lot.
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 02:47
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
