How to change value of a variable in exterior cells in parallel computation
Like Tree2Likes
  • 2 Post By hb12
Old   November 29, 2015, 15:59
Default How to change value of a variable in exterior cells in parallel computation
HBarati
hb12 is on a distinguished road
Hi ,
In parallel computing I tried to change value of a variable (for example a pressure or a UDM) in exterior cells of a partition. Nevertheless, information of exterior cells is accessible (like faces, nodes, etc), the value of the variable or UDM does not change. I used different macros.
Generally, is it possible to change values in cells of other partitions adjacent to the current partition?
I have to work with parallel option because of large number of cells.
Wang Changjun and Allen_ayt like this.
hb12 is offline   Reply With Quote
Old   August 20, 2019, 04:34
Allen_ayt is on a distinguished road
Hi!
I have came across the same problem. I'm wondering if you have solved it?
Thank you!
Allen_ayt is offline   Reply With Quote
Old   August 20, 2019, 05:10
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
Ansys Fluent Customization manual
look for begin_f_loop_ext
best regards
AlexanderZ is offline   Reply With Quote
Old   December 16, 2020, 03:24
Vincenzo Luci
vincenzolights is on a distinguished road
Has someone solved this problem? I need to write UDM of the exterior cell of one partition in the corresponding interior cell of another computational node. I know that partitions can exchange messages parallelizing UDF but it is tricky for my problem when I need to exchange continuously information between the exterior cell and adjacent one of the same node ID.
vincenzolights is offline   Reply With Quote
parallel computation, udf and programming
Any Procedure to setup parallel computation?? fluidmechanics SU2 Installation 10 July 21, 2017 05:31
parallel computation with PBS error tsevine SU2 4 July 4, 2014 07:21
parallel computation using v2.0.8 mistuning SU2 1 November 21, 2013 12:01
MPI and parallel computation Wang Main CFD Forum 4 April 3, 2005 07:40
Parallel computation problem in Tascflow dandy CFX 3 April 21, 2002 01:32
