Dynamic 3d mesh Negative Volume negative volume
Like Tree1Likes
  • 1 Post By bhargavbharathan
Old   November 19, 2015, 04:34
Default Dynamic 3d mesh Negative Volume negative volume
fredrick
fredrick is on a distinguished road
Hello people.
I need assistance and your suggestions. I have been trying to simulate a cantilever beam inside a fluid domain. My code seems to be working but failing at a paticular point due to negative volume. I observed this and found out that the cell skewness rises upto 1 and this is the point where simulation is failing. I have tried to:
1. decrease timesteps (i use time steps 0f 0.0001 1/100 of the frequency time period)
2. create fine mesh near the beam. I use remeshing and smoothing..
Can anyone help me write a code
fredrick is offline   Reply With Quote
Old   November 23, 2015, 17:13
Bhargav Bharathan
bhargavbharathan is on a distinguished road
1. Decreasing your time step does not alleviate the problem 100%.
2. Remesh your volume and make sure there is no skewness. Structured mesh should work.
3. In your dynamic mesh zones do not specify any deforming zones. Specify only the zones that move. Fluent specifies deforming zones automatically and you will face errors if you do it too.
4. Check your mesh methods settings.
For reference you can check the ANSYS Fluent 2D box falling in water tutorial.
-BB
fredrick likes this.
Last edited by bhargavbharathan; November 23, 2015 at 17:14. Reason: added reference
bhargavbharathan is offline   Reply With Quote
define grid motion, dynamic mesh, negative cell volume, udf
2d dynamic mesh negative volume tdbbz FLUENT 1 June 18, 2012 05:31
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
remeshing due to negative volume error Doginal CFX 1 August 21, 2011 22:50
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
