Macros for access turbulence intensity
Like Tree1Likes
  • 1 Post By `e`
Old   October 10, 2015, 09:00
Default Macros for access turbulence intensity
Astio Lamar
asal is on a distinguished road
Hello all!
I want to calculate some a value in a UDF and I need to have "turbulence intensity". Is there anyone here know how can I return this value?
I mean a macro such as " C_U(c,t)" which return turbulence intensity.
moreover, is there any macro which return velocity magnitude? or the only way is to return components and then find the magnitude?
asal is offline   Reply With Quote
Old   October 11, 2015, 17:36
`e`
`e` is on a distinguished road
Fluent doesn't store turbulence intensity by default. However, you can calculate this value as turbulence intensity is defined as the ratio between the root-mean-square turbulent velocity fluctuations and the mean velocity.
The velocity fluctuations can be computed as a function of the kinetic energy (for example, k-e) or via the Reynolds stresses (RSM model). The mean velocity (not stored as a separate value by default) is the magnitude of the individual components.
asal likes this.
`e` is offline   Reply With Quote
Turbulence intensity too high on the inlet trollreign FLUENT 1 December 10, 2023 22:10
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
Creating a new field from terms of the turbulence model HaZe OpenFOAM Programming & Development 15 November 24, 2014 14:51
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 04:11
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 18:15
