6DOF for spring valve motion problem
Like Tree1Likes
  • 1 Post By PRIDEmartins
Old   August 19, 2015, 03:08
Thumbs down 6DOF for spring valve motion problem
JEONGWOO2
ahehuhehuh is on a distinguished road
Dear all~
I want solve the problem that 6DOF constant spring motion in 2-D
Using DEFINE_SDOF_PROPERTIES
But it's results weird.. something likes function of sine..
How can i write 6DOF function?
Here are some attachment.
first, using the 6DOF
#include "udf.h"
#define spring_constant 1.5 /*idonknow*/
#define original_pin_cg_y 3.25e-4
DEFINE_SDOF_PROPERTIES(Pinconst_1_5, prop, dt, time, dtime)
real pin_movement_y;
prop[SDOF_MASS] = 6.792e-6;
prop[SDOF_IXX] = 6.4059e-11;
prop[SDOF_IYY] = 6.28e-13;
prop[SDOF_IZZ] = 6.4676e-11;
prop[SDOF_ZERO_TRANS_X] = TRUE;
prop[SDOF_ZERO_TRANS_Z] = TRUE;
prop[SDOF_ZERO_ROT_X] = TRUE;
prop[SDOF_ZERO_ROT_Y] = TRUE;
prop[SDOF_ZERO_ROT_Z] = TRUE;
pin_movement_y = (DT_CG(dt)[1] - original_pin_cg_y);
Message("DT_CG = %e, %e, %e\n",DT_CG(dt)[0], DT_CG(dt)[1], DT_CG(dt)[2]);
prop[SDOF_LOAD_F_Y] = - spring_constant * pin_movement_y;
Message("spring force = %e\n",prop[SDOF_LOAD_F_Y]);
model and mesh for simulation,
results of coordinate for <Time vs 'wall box positions'>
Thanks
ahehuhehuh is offline   Reply With Quote
Old   February 26, 2018, 14:36
Lucas Gasparino
LucasGasparino3110 is on a distinguished road
Hi there mate!!
Did you get any closure in your case? For me, the sine-like motion doesn't seem wrong, tbh. Is your UDF used as interpret or compiled? I'm having a similar case but with the addition of torsion, so I'm willing to try your solution, as it is the only reference I got that uses a spring...
Thank you very much!
LucasGasparino3110 is offline   Reply With Quote
Old   April 18, 2018, 16:39
Talking
Flavio Martins
PRIDEmartins is on a distinguished road
It is not wrong what you have done.
In my opinion, there are only two things missing in here:
I. a damping coeficient. Something like: -c*DT_VEL_GD(dt), on the force equation, in order to make the system more stable.
II. Descrease the time step.
For I: try using: zeta = c/2*sqrt(M*K), for correctly determing your damping coeficient, c.
For II, a good start point is: dt = fn/50 (fn = system's natural frequency, given by: fn = sqrt(k/m)/2*pi.
For me, in II, the frequency of vortex sheeding is also a good idea. Use the Strouhal nunber, St=0.2, to guess f_vortex e try doing the same.
Sorry for the bad English. I'm in a hurry in here.
Howl Wang likes this.
PRIDEmartins is offline   Reply With Quote
Modelling an initially closed valve which a fluid opens siw CFX 1 April 26, 2014 07:32
please help valve motion UDF g-wagon Fluent UDF and Scheme Programming 0 December 28, 2011 23:21
problem in writing CEL expressions for mesh motion hasan56 CFX 2 October 20, 2011 13:55
3D valve motion but no mesh motion with smoothing slaol2 FLUENT 1 September 22, 2011 19:06
Large Valve Flow Analysis - Inflation Problem sercan85 ANSYS Meshing & Geometry 2 June 1, 2010 15:02
