Error during interpreting UDF for VoF
Like Tree1Likes
  • 1 Post By pakk
Old   May 25, 2015, 11:24
Unhappy Error during interpreting UDF for VoF
Rafal
vekh is on a distinguished road
Hello!
I want to write UDF which will return coordinates of specific VoF fraction - let say alpha from = 0.5 to 0.55. I wrote UDF with use of C_VOF(cell, pt[]) but there was an error message label "store_vof_norm" not found.
Then I was try to interpret UDF from Ansys manual:
   This UDF is an implementation of the degassing boundary condition
 #include "udf.h"
 #include "sg.h"
 #include "sg_mphase.h"
 #include "flow.h"
 #include "mem.h"
 #include "metric.h"
 DEFINE_SOURCE(degassing_source, cell, thread, dS, eqn)
    real source;
    Thread *tm = THREAD_SUPER_THREAD(thread);
    source = -C_R(cell,thread)*C_VOF(cell,thread)/CURRENT_TIMESTEP ;
    C_UDMI(cell,tm,0) = source;
    dS[eqn] = -C_R(cell,thread)/CURRENT_TIMESTEP;
    return source;
 DEFINE_SOURCE(x_prim_recoil, cell, tp, dS, eqn)
    real source;
    Thread *tm = THREAD_SUPER_THREAD(tp);
    Thread *ts;
    ts = THREAD_SUB_THREAD(tm,1);
    source = -C_R(cell,ts)*C_VOF(cell,ts)/CURRENT_TIMESTEP*C_U(cell,tp);
   dS[eqn] =-C_R(cell,ts)*C_VOF(cell,ts)/CURRENT_TIMESTEP;
    return source;
 DEFINE_SOURCE(x_sec_recoil, cell, ts, dS, eqn)
    real source;
    Thread *tm = THREAD_SUPER_THREAD(ts);
    source = -C_R(cell,ts)*C_VOF(cell,ts)/CURRENT_TIMESTEP*C_U(cell,ts);
    dS[eqn] = -C_R(cell,ts)*C_VOF(cell,ts)/CURRENT_TIMESTEP;
    return source;
 DEFINE_SOURCE(y_prim_recoil, cell, tp, dS, eqn)
    real source;
    Thread *ts;
    source = -C_R(cell,ts)*C_VOF(cell,ts)/CURRENT_TIMESTEP*C_V(cell,tp);
    return source;
  DEFINE_SOURCE(y_sec_recoil, cell, ts, dS, eqn)
    real source;  Thread *tm = THREAD_SUPER_THREAD(ts);
    source = -C_R(cell,ts)*C_VOF(cell,ts)/CURRENT_TIMESTEP*C_V(cell,ts);
    return source;
 DEFINE_SOURCE(z_prim_recoil, cell, tp, dS, eqn)
    real source;
    Thread *ts;
    source = -C_R(cell,ts)*C_VOF(cell,ts)/CURRENT_TIMESTEP*C_W(cell,tp);
    return source;
  DEFINE_SOURCE(z_sec_recoil, cell, ts, dS, eqn)
    real source;
    source = -C_R(cell,ts)*C_VOF(cell,ts)/CURRENT_TIMESTEP*C_W(cell,ts);
    return source;
I want just to try if that will work but there is again error:
Error: D:\\Fluent\\Testy\\test3.c: line 80: label "store_vof_norm" not found (pc=33).
Error: D:\\Fluent\\Testy\\test3.c: line 80: label "store_vof_norm" not found (pc=180).
Error: D:\\Fluent\\Testy\\test3.c: line 80: label "store_vof_norm" not found (pc=256).
Error: D:\\Fluent\\Testy\\test3.c: line 80: label "store_vof_norm" not found (pc=336).
Error: D:\\Fluent\\Testy\\test3.c: line 80: label "store_vof_norm" not found (pc=412).
Error: D:\\Fluent\\Testy\\test3.c: line 80: label "store_vof_norm" not found (pc=506).
Error: D:\\Fluent\\Testy\\test3.c: line 80: label "store_vof_norm" not found (pc=582).
Error: D:\\Fluent\\Testy\\test3.c: line 80: label "store_vof_norm" not found (pc=662).
Error: D:\\Fluent\\Testy\\test3.c: line 80: label "store_vof_norm" not found (pc=738).
Error: D:\\Fluent\\Testy\\test3.c: line 80: label "store_vof_norm" not found (pc=832).
Error: D:\\Fluent\\Testy\\test3.c: line 80: label "store_vof_norm" not found (pc=908).
Error: D:\\Fluent\\Testy\\test3.c: line 80: label "store_vof_norm" not found (pc=988).
Error: D:\\Fluent\\Testy\\test3.c: line 80: label "store_vof_norm" not found (pc=1064).
Is there any special action to perform before interpreting such UDF or there is some kind of different error. I will be grateful for any tip.
vekh is offline   Reply With Quote
Old   May 25, 2015, 20:24
`e`
`e` is on a distinguished road
Some macros require compiling the UDF instead of interpreting, try compiling your UDF. The examples provided in the UDF manual should work.
`e` is offline   Reply With Quote
Old   May 25, 2015, 21:20
Rafal
Thanks for reply. I'll try to do this tomorrow.
Update:
It works! Thank you man!
Old   March 16, 2017, 11:05
Default how to solve.
Xuzhi Du
Ronnie-Du is on a distinguished road
But how do you solve it. I also encountered such a problem.
Ronnie-Du is offline   Reply With Quote
Old   March 17, 2017, 09:49
pakk will become famous soon enough
The first post shows the problem.
The second post shows the solution.
The third post confirms that the solution works.
The fourth post is you, asking what is the solution.
The fifth post is the one you are reading now.
Ronnie-Du likes this.
pakk is offline   Reply With Quote
Old   February 15, 2018, 03:08
Default store_vof_norm
Meisam
Meisam1300 is on a distinguished road
Hello all,
I encountered the error " store_vof_norm" not found when interpreting my file in fluent 16.2
I also compiled the udf code successfully but I am still getting the same error when interpreting.
can anyone help me to fix it ?
Thank you in advance.
Meisam1300 is offline   Reply With Quote
Old   February 15, 2018, 04:40
The solution is to compile... which you have already done succesfully.
So, use the compiled version, and don't try the interpreted one.
Old   February 16, 2018, 14:29
Meisam
Thank you Pakk.
The problem is that when I compile and load it successfully and I want to call the udf file for boundary conditions I receive the error "no udf function is loaded".
Can you help me fix it. ?
Thank you again
Old   February 19, 2018, 06:28
Does you code include a boundary condition? The code above only has source conditions...
Otherwise: are you sure that compiling went fine? Did you check the screen if any errors showed up?
Old   March 12, 2018, 02:57
Post
Lee
Lee 小亢 is on a distinguished road
hello~
I want to use the degassing boundary for my case, but I don't know how to load this UDF to the layer of cells next to the outlet as Fluent UDF manual told,
can you help me?
Thx a lot~
Lee 小亢 is offline   Reply With Quote
the DEFINE_MASS_TRANSFER is only a interpreting udf IN ANSYS 14.0 fangdian Fluent UDF and Scheme Programming 7 April 19, 2016 04:53
syntax error while interpreting the UDF rohit chothave Fluent UDF and Scheme Programming 2 July 13, 2013 12:09
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 07:43
parse error with interpreting UDF ivanbuz Fluent UDF and Scheme Programming 2 August 13, 2009 19:29
interpreting UDF Muhammad Shakaib FLUENT 1 January 24, 2006 11:58
