how to impose experimental data as boundary condition in Fluent 6.3.26 |
cherche-du-paix
Rep Power: 12 ![]() |
hi
how to impose experimental data as boundary condition in Fluent 6.3.26 I have this data for temperature profile how can I introduce it as user define for boundary condition time(h) 7:00 8:00 9:00 10:00 11:00 12:00 13:00 14:00 15:00 16:00 17:00 18:00 19:00 Temperature 37,59 45,88 53,89 60,8 65,78 67,85 69,3 67,03 64,96 59,73 52,25 44,37 37,77 |
Guang
Rep Power: 11 ![]() |
you can use udf to set a boundary condition of temporal varied temperature
Rep Power: 15 ![]() |
why don't you fit an expression on your experimental data and then having the equation, you can use DEFINE_PROFILE to create your own bc for the temperature.
Hi duina,
As per my understanding, you want to change temperature boundary condition per hour but it is not clear to me which type of boundary condition it is (I mean mass_flow_inlet,pressure_outlet ?) I assume, you know the number of time steps per hour. Before starting iterations, define function as follows in console (You have to paste complete syntax in one go, not line by line) Code:
(define my_temperature (lambda (my_temp) (let () (begin (ti-menu-load-string (format #f "/define/boundary-conditions/pressure-outlet pressure_outlet_face_zone no ~a no ~a n y n n ~a n ~a n ~a n ~a y y y y n 0 n 0 n 0 n 0 n n n" 0 my_temp 0.1 0.1 0.1 0.1)) ) ) ) ) Code:
(my_temperature 45.88) Here in my case, i have considered a random definition of boundary condition. For you, the syntax in bracket (ti-menu-load-string .....) will change accordingly. |
cherche-du-paix
thank's maverick123 and Sun to replying me
i wante to run my simulation , for 0.1 s times steps and the temperature varied each hour in boundary condition i have this data experimental temperature to introduce it as user define it is like when t = 1 h to 2 h ( mean ) from 7:00 to 8:00 Temperature= 37°C t= 2 or 72000 sec (from 8:00 to 9:00 ) T=45,88 °C . . . . . . and my simulation steps time run for 0.1 s how i can create this user define to define the profile of temperature each hour thank's |
#6 | |
Rep Power: 16 ![]() |
The code you posted doesnt look like a UDF one. Its likely the same format as sentences in a profile file. Could you tell me what it is exactly? How to write such a script and hook it inFLUENT? Thanks |
#7 | |
The code i have written is not UDF, it is the scheme function. As per my assumption, there is not fix function/expression (which is convenient to code in UDF) for above mentioned temperature boundary condition. So I defined a function which will set require value to the BC after certain iterations. As per problem, if BC has to be changed after 1 hr, there should be certain number of iterations in between. In journal or while running manually I will update the BC by just passing required value to my defined function. Thanks |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
You can also define it as a profile. The syntax for a profile file is pretty simple but I've never made a transient one. here's an example for a spatial profile.
((name point 2 1) (x 0.000000e+00 0.000000e+00) (y 1.735112e-05 5.206682e-05) (axial-velocity 2.427940e+01 2.426885e+01) Write your data to a text file in similar format and read it into fluent as a profile. |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
How to transfer boundary condition from Openfoam to fluent | sachinlb | OpenFOAM Post-Processing | 1 | January 6, 2012 01:41 |
problem about periodic boundary condition in Fluent | winnawinna | FLUENT | 0 | December 28, 2010 23:32 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 11:32 |
