modify a intern variable of Fluent with scheme and UDF
Like Tree1Likes
  • 1 Post By Kokemoor
Old   February 27, 2015, 11:25
Default modify a intern variable of Fluent with scheme and UDF
fanch33 is on a distinguished road
Hi everybody,
I want to modify at each time step in each cell, the constant Cepsilon2 (Ceps2) from the k-epsilon RANS model that we can access from the viscous model panel.
In my UDF, I compute the value I want for Ceps2 in a C_UDMI variable.
From what I read, I think that I need to send this value from the UDF to a scheme program (using RP_Set_Real) to update the value of Ceps2.
How can I get back the value with a scheme program ?
Thanks for your help
Fanch
fanch33 is offline   Reply With Quote
Old   March 2, 2015, 03:32
maverick123 is on a distinguished road
Hi Fanch,
As per my understanding, you have to use DEFINE_ADJUST routine, not rp_vars.
Best Regards
maverick123 is offline   Reply With Quote
Old   March 2, 2015, 11:54
Andrew Kokemoor
Kokemoor is on a distinguished road
The turbulent model constants are actually already stored as Scheme variables, so you shouldn't need to write any Scheme code. The constant C2-Epsilon for the RNG model is stored in the variable rng-kec2. If you use RP_Set_Real("rng-kec2",Ceps2) in your DEFINE_ADJUST macro, I don't think you'll need to do anything else.
ingpeppe likes this.
Kokemoor is offline   Reply With Quote
Old   March 2, 2015, 12:01
thank you for your answer Kokemoor.
I thought that I needed to use a scheme because my company give me a manual on that, but a bit obsolete...
But you're right, I tried RP_Set_Real in my UDF this morning and the Ceps2 value were updated as I wanted.
Anyway, thanks for your answer
changing scheme variable with UDF? Wagemakers FLUENT 17 September 30, 2015 15:34
Calling zone name, zone id and total pressure from Fluent scheme to UDF kuldip Fluent UDF and Scheme Programming 2 October 6, 2014 01:23
udf for chemical reduction scheme yorelchr Fluent UDF and Scheme Programming 0 September 20, 2013 11:55
How to combine UDF and Scheme? ali hemmati Fluent UDF and Scheme Programming 3 March 19, 2011 15:45
Scheme and Fluent UDF? Arthur Valais FLUENT 11 January 31, 2000 14:19
