Getting coordinates of the center of a boundary
Like Tree1Likes
  • 1 Post By pakk
Old   February 6, 2015, 07:44
Default Getting coordinates of the center of a boundary
Rui_27 is on a distinguished road
Hello to all,
Anyone knows how to get the coordinates of the center of a boundary (namely, velocity-inlet type)?
I have a straight channel with pores on its bottom surface, from where liquid water emerges. I want to get the coordinates of the center of each pore to be used in my udf calculations.
Any ideias?
Thanks!
Rui
Rui_27 is offline   Reply With Quote
Old   February 6, 2015, 08:56
pakk will become famous soon enough
Some scheme magic:
(display
 (map
  (lambda (zone)
   (format #f "~a: (~a,~a,~a)\n" zone
    (pick-a-real
     (format #f "/report/surface-int/area-weighted-avg ~a () x-coordinate no" zone)
    (pick-a-real
     (format #f "/report/surface-int/area-weighted-avg ~a () y-coordinate no" zone)
    (pick-a-real
     (format #f "/report/surface-int/area-weighted-avg ~a () z-coordinate no" zone)
  (filter
   (lambda (zn) (eq? (zone-type (get-zone zn)) 'velocity-inlet)) (inquire-zone-names)
Copy-paste this in the text-user-interface, and you will see a list appear.
Probably you want it in a udf, and not in scheme, but it was nice to get this working in scheme.
anan12345 likes this.
pakk is offline   Reply With Quote
Old   February 6, 2015, 09:40
Hi pakk,
Thanks for your answer.
I did what you said, but nothing happening, and Fluent crashed.
Any suggestion for doing it in a udf?
Regards,
Rui
Old   February 6, 2015, 11:12
upeksa is on a distinguished road
You can look for the cell with the highest cell wall distance (C_WALL_DIST) or you can calculate the average x, y and z coordinate, it is not very complex to calculate it via UDF.
But unless your boundary has a simple geometry, it will not make much sense in any case.
upeksa is offline   Reply With Quote
Old   February 2, 2022, 09:04
anan12345 is on a distinguished road
Originally Posted by pakk View Post
Some scheme magic:
(display
 (map
  (lambda (zone)
    (pick-a-real
    (pick-a-real
    (pick-a-real
  (filter
Thanks pakk, I've been searching for this for a couple of days now.
anan12345 is offline   Reply With Quote
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
inlet velocity boundary condition murali CFX 5 August 3, 2012 09:56
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
Solver error message!!! IoSa CFX 1 September 14, 2006 05:48
?? How to get cell center coordinates? erica FLUENT 0 May 11, 2005 23:02
