philosophy of using Headers!
Like Tree1Likes
  • 1 Post By mprinkey
Old   January 27, 2015, 05:34
Question philosophy of using Headers!
Majid Zarif
Majid Zarif is on a distinguished road
Hi Every body
I know that every UDF file should include
#include "udf.h"
but I saw other things like:
sg.h
or
prop.h
do any body know how can we understand how to use these headers?and also WHY we use them?
Thanks
Majid Zarif is offline   Reply With Quote
Old   January 27, 2015, 11:04
Michael Prinkey
mprinkey will become famous soon enough
Header files in C are essentially just another container for functions, variable declarations, and macros. They are not usually compiled by themselves into a standalone executable files. "Proper use" of header files are mostly to provide function prototypes for functions that are defined in a different .c file or exist in a pre-compiled library or executable, and maybe some supporting macros.
That is the case with udf.h. That header file (and it is distributed as source code with FLUENT ANSYS) has function prototypes and (many) macro definitions. F_C0, C_UDMI, etc are all defined as macros. All of the variables, function prototypes, and macros that UDFs generally need to access are defined in the udf.h file. But, there are other header files as well and those may contain function prototype/macro definitions that are not in udf.h but still may be useful. What those variables are and what use they are can only be sorted out by careful reading of the header files and trial-and-error testing, or by getting documentation or assistance from ANSYS.
Majid Zarif likes this.
mprinkey is offline   Reply With Quote
Old   January 27, 2015, 13:43
Majid Zarif
So it's essential to know other header's usage in UDF ?
I mean I can always use udf.h instead of these headers?
Old   January 27, 2015, 13:46
Michael Prinkey
Likely not. udf.h has most everything you should need to code UDFs.
can not include Windows.h and sys/stat.h headers eromon84 Fluent UDF and Scheme Programming 3 February 7, 2017 06:38
[ICEM] Blocking Philosophy Query aerospaceman ANSYS Meshing & Geometry 4 June 15, 2011 12:46
Borked license headers mwild OpenFOAM Bugs 2 July 2, 2010 05:34
ubuntu 9.10 64bit - wmake missing headers soeren87 OpenFOAM Installation 5 November 11, 2009 11:01
Philosophy of implicit solution of different regions Louis Le Grange OpenFOAM 0 October 5, 2009 11:53
