Dynamic mesh Problem: How can I set UDF to the motion of train?
Like Tree1Likes
  • 1 Post By vasava
Old   January 25, 2015, 10:56
Default Dynamic mesh Problem: How can I set UDF to the motion of train?
Majid Zarif
Majid Zarif is on a distinguished road
Hi Every body
I want to simulate this problem in fluent by dynamic mesh ,PLAESE help me how to set the dynamic mesh settings? and ...
How can I set UDF to the motion of train in this problem?
Thanks
This is the link of problem....:
https://www.dropbox.com/s/wv8mg77pyi...unnel.jpg?dl=0
Majid Zarif is offline   Reply With Quote
Old   January 26, 2015, 07:28
Paritosh Vasava
vasava will become famous soon enough
You could use DEFINE_CG_MOTION macro. See the following example
DEFINE_CG_MOTION(butterfly_flex_UDF, dt, cg_vel, cg_omega, time, dtime)
  cg_vel[0] = 0.0; //X-velocity
  cg_vel[1] = 0.0; //Y-velocity
  cg_vel[2] = 0.0; //Z-velocity
  cg_omega[0] = 0.0;
  cg_omega[1] = 0.0;
  cg_omega[2] = 0.0;
Majid Zarif likes this.
vasava is offline   Reply With Quote
Old   January 26, 2015, 09:23
Majid Zarif
  cg_omega[0] = 0.0;
  cg_omega[1] = 0.0;
  cg_omega[2] = 0.0;
thanks for your reply
As you said I should use this code if I want to move in X-direction with velocity of 0.5m/s?
#include "udf.h"
DEFINE_CG_MOTION(Train_Motion, dt, cg_vel, cg_omega, time, dtime)
cg_vel[0] = 0.50; //X-velocity
Old   January 27, 2015, 03:38
Paritosh Vasava
Yes. However you must also check some tutorial for mesh motion. You have such a large problem (in terms of mesh size) at hand. The mesh motion will make it even more challenging.
Also in my opinion simulating the train entering and leaving the domain will also be another challenge. I have tried such an example but I did not have any success with it.
Old   January 27, 2015, 03:44
Majid Zarif
As you said we don't have any solution?!
Is the way of changing CG motion is the solution?I tried it the fluent responded that "considering no motion"!
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
spring-based dynamic mesh problem uhhaha2157 FLUENT 0 January 1, 2014 08:38
UDF dynamic mesh problem! gaozhengyu Fluent UDF and Scheme Programming 1 December 13, 2012 01:19
Dynamic mesh update problem. David FLUENT 3 March 15, 2012 06:02
