Define time step size with max or min of Temp in a domain
Like Tree1Likes
  • 1 Post By pakk
Old   December 17, 2014, 14:33
Lightbulb Define time step size with max or min of Temp in a domain
hosein
ho3ein.agl is on a distinguished road
Hi cfd-online
I have a very very sensible unsteady simulation and it must run with small time step size.
I want to use DEFINE_DELTAT and set Deltat function of some cell variable in a domain.
for example
if max Temp < T1 then Deltat=a
if max Temp >= T1 then Deltat=b
if max Liquid fraction > 0 then Deltat=c
is it possible to do that?
I think "Looping Over Cell Threads in a Domain (thread_loop_c)" can help me if I use that in DEFINE_DELTAT macro.
thank you
ho3ein.agl is offline   Reply With Quote
Old   December 18, 2014, 06:30
hosein
my udf is:
Red number is line number in udf commands .
DEFINE_DELTAT(mydeltat, domain)
	real time_step;
	real T_max=0.0 ;
	real T1=303.0 ;
	real T2=300.5 ;
	real T3=304.0 ;
	Thread t;
    cell_t c;
54	thread_loop_c(t,domain)
56		begin_c_loop(c,t)
58			temp = C_T(c,t);
			if (temp > T_max || T_max == 0.0) T_max = temp;
		end_c_loop(c,t)
	if (T_max < T1) time_step = 1.0;
	else time_step = 0.00001;
	return time_step;
error after build in compiler window:
Done.
(chdir "libudf")(chdir "win64\2ddp")# Generating ud_io1.h
Paper_PCM_Prop_and_DeltaT_v2.c
..\..\src\Paper_PCM_Prop_and_DeltaT_v2.c(54) : error C2440: '=' : cannot convert from 'thread_struct *' to 'Thread'
..\..\src\Paper_PCM_Prop_and_DeltaT_v2.c(54) : error C2088: '!=' : illegal for struct
..\..\src\Paper_PCM_Prop_and_DeltaT_v2.c(54) : error C2232: '->next' : left operand has 'struct' type, use '.'
..\..\src\Paper_PCM_Prop_and_DeltaT_v2.c(56) : error C2232: '->nelements' : left operand has 'struct' type, use '.'
..\..\src\Paper_PCM_Prop_and_DeltaT_v2.c(58) : error C2232: '->storage' : left operand has 'struct' type, use '.'
Done.
whats wrong in udf?
Old   December 18, 2014, 06:57
pakk will become famous soon enough
Instead of making "t" a thread variable, in
Thread t;
you should make it a pointer to a thread variable:
Thread *t;
ho3ein.agl likes this.
pakk is offline   Reply With Quote
Old   December 18, 2014, 07:59
hosein
ok , Its work
define_deltat
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
time step directories naming issue Andrea_85 OpenFOAM 3 April 3, 2014 09:38
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
