December 9, 2014, 09:17 |
how to check UDFs code errors?
Rep Power: 12 |
Hi, I would like to know how to check my UDFs coding in order to impute it in Fluent. For example, I have just been trying to input a parabolic velocity profile as an inlet of a straight pipe (emulating a fully developed velocity profile). I saw a couple of examples online, so I used them as template, I wrote the ".c" file and compile it and load it in Fluent, it worked.
However, if I want to check any errors within the code I tried to compile it on Visual Studio, before even opening Fluent, so that I could know whether I had some errors on my coding or not. However, it seems to me that Fluent uses a C programming based language, but it is not exactly C language, because the way I need to define functions and variables is not the same. This is a basic example of UDF: #include "udf.h" #define Q 1.5625e-5 //unit m3/sec #define Diameter 4.5e-3 //unit m DEFINE_PROFILE(axialVelocity,t,i) { real x[ND_ND]; real r,Area; face_t f; Area=(M_PI/4.0)*pow(Diameter,2); begin_f_loop(f,t) { F_CENTROID(x,f,t); r=sqrt(pow(x[0],2)+pow(x[1],2)); F_PROFILE(f,t,i)=(2.0*Q/Area)*(1-pow(2.0*r/Diameter,2)); } end_f_loop(f,t) } When I try to compile this on Visual Studio, it doesn't even know what "real" is. I have been going through a C language manual, and there is no variable that could be defined as "real", the only types of variables are: int char float double So I wonder how should I approach this issue. Also, if I just write the code on a ".txt" file and save it as a ".c" it works, and Fluent is able to compile it if the code is correct. However, if there is a mistake in the code, it gives and error, but it wouldn't even say in which line of code the error is... I find this pretty disappointed. I know in CFX, you can easily create UDFs within even needing to do a ".c" file, and if you happen to create a ".c" file and compile it, it would give you and error and where the error is. I would like to know which editor and compiler people usually use to create and check their UDFs before compiling and loading them into Fluent. And I would like to know which type of C language these UDFs should be written in, since I would need to learn about it. Thanks a lot in advance for you time and help. Sincerely, Guillermo Jimeno |
December 9, 2014, 09:49 |
Cees Haringa
I use visual studio and code::blocks. Anyway, types like real are indeed not part of regular C. You can define your own types for debugging, of course, but debugging the code as implemented in FLUENT is, as far as I know, not possible in any editor. The only reason I use VS or CB is because it does point out the obvious syntax errors (forgotten parenthesis and so on), and because I can check whether a function works if I write it as a standalone script, before modifying it to something hookable to FLUENT.
Regarding errors, FLUENT does give the line the error occurs in, and typically the reason (if it is a syntax error at least). For other errors, like occurance of NANs, I can only recommend to write a stand-alone version of the script, and test if the calculated output is correct. |
December 9, 2014, 21:42 |
Thanks and further inquiries
Rep Power: 12 |
Hi CeesH! Thanks a lot for your quick and useful reply. I'll follow your advise and limit VS purpose to check simple code errors.
Apologies for my lack of knowledge, but... what exactly is a stand-alone scrip? And how could I create it from my UDF code? Can that be compile and tested on VS? On a different note, in order to teach myself the specific C language that Fluent uses, I would like to know how I should refer to and define variables in order for Fluent to understand it. Like how exactly Fluent calls viscosity, density, radial coordinates, etc, etc. Is there anywhere where I could find this information? Like a table of variables and how they are called by Fluent? I know there is such kind of document available for CFX: ANSYS Help Viewer > CFX > 16.Reference Guide > 16.2.Variables in ANSYS CFX There you can find all kinds of variables. Is there an equivalent document for Fluent? I have been trying to look for it, but I couldn't find it. Thanks a lot once again for you time and help. Sincerely, Guillermo |
December 10, 2014, 04:44 |
Rep Power: 27 |
"real" (and "DEFINE_PROFILE", "face_t", "begin_f_loop", "F_CENTROID", "F_PROFILE" and "end_f_loop") are defined in "udf.h", which you include in the first line of your code.
If you compile this in fluent, fluent knows where the file "udf.h" is located. It should be possible to compile the udf in visual studio (I never tried it), but the problem is that visual studio does not know where the file "udf.h" is located. Once you let visual studio know where to find that file (and I have no idea how that works), it should be possible to compile it. There is an entire section in the Fluent help dedicated to UDF's, the "UDF manual". It also includes tables of variables with their names and short descriptions. |
December 10, 2014, 07:23 |
Cees Haringa
with stand-alone script I mean something that would run independent of FLUENT, just a separate executable.
Say I'd write a UDF for a first order reaction rate, that would look something like: Code:
#include "udf.h" #define K1 0.001 DEFINE_VR_RATE(...all those things...) { int i = 0; real C_MOLE = (C_YI(c,t,i)/mole_weight[i]) * C_R(c,t); *rate = K1*C_MOLE; *rr_t = *rate;} Code:
#include "stdio.h" #define K1 0.001 int main() { int i = 0; double C_MOLE = (C_YI(c,t,i)/180) * 1000; rate = K1*C_MOLE; return rate } Regarding learning C, you can use the FLUENT manual for some basic understanding. But of course it doesn't hurt learning the actual language by following a C course or buying a good instruction book. In the end, there is no difference between C and `FLUENT C' |
December 10, 2014, 18:57 |
Rep Power: 12 |
Thank you guys a lot for the replies, it really helped.
Now everything is becoming clearer to me. May I ask one more question, which might or not be directly related to UDFs. I´m just aiming to input a fully developed velocity profile in the inlet of my geometry. For a 2D geometry I created the following UDFs, which worked perfectly well, since the 2D geometry was just half of the symmetry centre section (the system is axisymmetric), the origin of the geometry was in the symmetry axis of the inlet surface. Code:
#include "udf.h" #define v0 0.0075 //unit m/sec #define radius 0.01 //unit m DEFINE_PROFILE(inlet_x_velocity, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real y; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1]; F_PROFILE(f, thread, position) = 2*v0*(1-(pow(y/radius,2))); } end_f_loop(f, thread) } Code:
#include "udf.h" #define v0 0.0075 //unit m/sec #define radius 0.01 //unit m DEFINE_PROFILE(inlet_x_velocity, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real y; real z; real r; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1]; z = x[2]; r = sqrt(x[1]*x[1] + x[2]*x[2]); F_PROFILE(f, thread, position) = 2*v0*(1-(pow(r/radius,2))); } end_f_loop(f, thread) } On a different note, am I right saying that when defining the “x” array in a UDF, for 2D: real x[ND_ND] xx = x[0]; yy = x[1]; And, for 3D: real x[ND_ND] xx = x[0]; yy = x[1]; zz = x[2]; ? Where “xx”, “yy” and “zz” are the actually “x”, “y” and “z” coordinates respectively. Thank you so much for all the help. Regards, Guillermo |
compile a udf, compile error, fluent - udf, udf and programming |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
Please check the following code | Nagi | FLUENT | 0 | February 12, 2009 10:18 |
Fluent UDF's / dynamic meshing errors | Peter | FLUENT | 2 | November 6, 2005 04:36 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 16:56 |
