Problem running in batch
Like Tree1Likes
  • 1 Post By renatovj
Old   December 2, 2014, 16:43
Question Problem running in batch
Renato Venturatto Junior
renatovj is on a distinguished road
Hello my friends,
Need your help very much!
I`m running a case of a simple cylinder with water flowing around it (Linux,2D,lam,transient Fluent 13.0).There`s a UDF hooked to the case and I`m tryinng to run it in batch mode.The following errors occur only when the UDF is hooked to the case:
Comand:
venturatto/teste_FSI_cilindro_2% fluent 2ddp -g -t1 < parameters.txt > output_cylinder_FSI_2_UDF
Error:
Primitive Error at Node 0: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (lnamd64).
No such file or directory
/opt/home/venturatto/teste_FSI_cilindro_2/libudf/lnamd64/2ddp_node/libudf.so
Error: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (lnamd64).
/opt/home/venturatto/teste_FSI_cilindro_2/libudf/lnamd64/2ddp_host/libudf.so
Error Object: #f
Stack backtrace generated for node id 0 (pid = 28552) on signal 11 :
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp_node/fluent_mpi.13.0.0[0x13f2ff6]
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp_node/fluent_mpi.13.0.0[0x13f6e68]
/lib64/libc.so.6(+0x34e10)[0x7f8ba3332e10]
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp_node/fluent_mpi.13.0.0(user_sources+0x49f)[0x4ab70f]
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp_node/fluent_mpi.13.0.0[0x833584]
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp_node/fluent_mpi.13.0.0[0x84a7f0]
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp_node/fluent_mpi.13.0.0(Solve_V+0x155)[0x830ee5]
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp_node/fluent_mpi.13.0.0[0x82f5fe]
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp_node/fluent_mpi.13.0.0(Models_Send_update_solve+0x194)[0x6af3d4]
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp_node/fluent_mpi.13.0.0[0x5c794b]
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp_node/fluent_mpi.13.0.0(Flow_Iterate+0xa2)[0x5c68c2]
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp_node/fluent_mpi.13.0.0[0x64d8db]
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp_node/fluent_mpi.13.0.0(eval+0x7cc)[0x140841c]
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp_node/fluent_mpi.13.0.0(PRF_Command_Start+0x110c)[0x67f7ac]
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp_node/fluent_mpi.13.0.0(PRF_Node_repl+0x2e)[0x67dcde]
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp_node/fluent_mpi.13.0.0(main+0x332)[0xf62482]
Check the file fluenterror.log for details.
Please include this information with any bug report you file on this issue!
Primitive Error at Node 0: received Segmentation Violation
Error: Compute node encountered error
Error Object: #f
I tried to substitute the specification of the number of cores (-t1) for:
Command:
venturatto/teste_FSI_cilindro_2% fluent 2ddp -g -i < parameters.txt > output_cylinder_FSI_2_UDF
Which gives the error:
venturatto/teste_FSI_cilindro_2% fluent 2ddp -g -i < parametros.txt > saida_cilindro_FSI_2_UDF
/opt/cfd/fluent13/v130/fluent/fluent13.0.0/cortex/lnamd64/cortex.13.0.0 -f fluent -g -newcx (fluent "2ddp -r13.0.0 -path/opt/cfd/fluent13/v130/fluent")
Starting /opt/cfd/fluent13/v130/fluent/fluent13.0.0/lnamd64/2ddp/fluent.13.0.0 -cx sgi3:57287:44763
Welcome to ANSYS FLUENT 13.0.0
Copyright 2010 ANSYS Inc.
All Rights Reserved. Unauthorized use, distribution or duplication
is prohibited. ANSYS and FLUENT are trademarks or registered trademarks
of ANSYS, Inc. or its subsidiaries in the United States or other countries.
Build Time: Oct 11 2010 23:42:53 EDT Build Id: 10703
Loading "/opt/cfd/fluent13/v130/fluent/fluent13.0.0/lib/flprim.dmp.1119-64"
Done.
Error: Divergence detected in AMG solver
Error Object: #f
Please, any ideas?
renatovj is offline   Reply With Quote
Old   December 15, 2014, 08:15
Default Solution
I found a solution!
The problem occurred because I had a UDF of the EXECUTE_ON_DEMAND type, used to initialize the variables of the case.
I was not telling Fluent to execute this UDF in my "parameters.txt" file.
mhamad likes this.
divergence detected, segmentation error, udf and programming
Problem running movingCylinders case in parallel with foam-extend-3.1 mhkenergy OpenFOAM Running, Solving & CFD 5 March 3, 2017 06:20
problem with running shape_optimization modul Edris SU2 Installation 5 October 23, 2014 11:38
batch file problem Ansys CFX 15.0 papteo CFX 2 January 16, 2014 13:28
[Workbench] 'Batch mode' ICEM CFD problem 86682164 ANSYS Meshing & Geometry 0 August 22, 2013 17:53
Problem with running FoamX in a distributed environment susana OpenFOAM Pre-Processing 1 March 28, 2007 18:11
